Anyone blown a stock bottom end?
St. Jude Donor '08-'09
Did you diagnose the problem?What broke.Was it a rod,rod bolt ,piston etc...
Just wondering what is the weakest link in the bottom end.
Thanks.
Thanks.
Former Vendor
All depends on application. H/C high RPM change rod bolts/rods and if your going this far you may as well change the pistons. For FI up to 550-600 rwhp you need to run a really safe A/F ratio and timing as the piston ring lands can't take any rattling.
It's called Hyperuetetic Alloy Pistons. The silica content makes them very brittle and the ring lands tend to snap like a cracker if you get any detonation....no room for errors with them at all.
About 7 years ago I found this out. It's really easy to tell when the pistons break...if the dipstick doesn't pop up and spray oil all over the place..you can do a compression test and the cylinders that come up 70-100 psi lower then the rest....are toast. I broke 4 piston ring lands.
For a bent rod I have only heard on at the track...it was knocking really loud.
Pro Mechanic
C5 of Year Finalist (performance mods) 2019
2017 C5 of the Year Finalist
2016 C5 of the Year Finalist
2015 C5 of the Year Finalist
I Believe In The Beer Fairy
Didn't shred the bottom end, but tore the valvetrain apart. Cam gear ripped out of the camshaft, PTV contact on ALL ehxaust valves, bent six exhaust valves to the point of being stuck open. Number 7 was a little loose in the cylinder upon teardown but that's it.
I think earlier LS1's had some rod bolt failures until after the C5R effort exposed the weakness...trying to remember but I think there were some rod bolt factory fixes around the 2000 model year. But there has been people on here in the earlier days that experienced rod bolt failures.
For me it was the #7 piston ring that went!
I started to have excessive crank pressure/blowby and at times would blow the valve cover gasket out and then finally it blew out the ring
here's a couple of pics:
Thanks,Matt
Thanks,Matt
Supporting Tuner
Melted #7 & #5.
