Timing/Meth/LS6/Boost
Old Mar 1, 2009 | 06:53 PM
user_name's Avatar
user_name
Default Timing/Meth/LS6/Boost
How much timing are you guys running at peak boost with your ls6 motors on meth? I'm running a 50/50 meth mix with 11-13psi. Timing is set to 14 in the peak tq areas. Just wondering how much people are getting away with. I'm not going to push it. I expect good numbers like this on the dyno. So far it has only been street tuning.
Old Mar 1, 2009 | 07:08 PM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
Straight meth 18psi, 18° timing, 93octane pump gas and never a knock. My motor is 9.5:1 though.
Old Mar 2, 2009 | 10:23 AM
user_name's Avatar
user_name
Are you still running ls6 heads?
Old Mar 2, 2009 | 10:58 AM
EVLZ06's Avatar
EVLZ06
stock ls6....10psi, 16deg timing, 93oct and pure meth.
Old Mar 2, 2009 | 11:30 AM
glennd's Avatar
glennd
I have 20* of timing. 100% meth with 2 #10 nozzels. 93 octane and
9.2:1 C/R. I also have A/F around 10 under boost.
Old Mar 2, 2009 | 12:11 PM
BLOWNBLUEZ06
Yep. Patriot heads. 66cc combustion chambers.
To Timing/Meth/LS6/Boost
