STS haters heres your chance to let loose
Because the op has the motor to make that power.
On stock motors they are dogs. That's a fact. No STS car has touched 640rwhp with the stock bottom end on pump fuel while my blower car was doing that with stock heads and without meth.
When you make 800+ at the tires you can come back, until then you're talking out of your ***. Post up those almighty dyno numbers BC.
thats exactly what i wanted to know. Thank you for the helpful information.
Back in '02 we worked on a mid engine Ferrari 308 that had a rear mount turbo. Part of the internals of the catalytic converter had broken loose and shot into the turbo, ruining it. Every now and then we'll have a C5 or C6 on our dyno and we'll see bits of the cats on the ground behind the tailpipes, just make sure that if you go with an STS, take the cats off the car. Bob
I had Random High Flow Metal Matrix cats installed on mine. In your opinion/experience have they or can they break up like regular cats? Thanks!
I believe they can. I had those put on when MTI did headers on my car and it took a while but I got a piece lodged on one side where the end split from one to two tips.
Thanks for an honest opinion from someone who knows from experience. Not someone who is talking through their a$$ because the mouth don’t know any better. I am not sure of their preference but I am sure it is not a perfect set up either. Like the original post stated he was not building a track car only a fun to drive car.
The point of the thread was for an STS hater like myself to be able to air out what we don't like about them. There is to much work involved to get them to run with the other setups.
I didn't mention the cat issue because I wouldn't run cats with any FI setup.
hmmmmm can someone point STEALTH 99 C5 to this thread..... or is he too busy running in the 8s to even read it! lol
(for those that dont know STEALTH is running a Cartech built 402 with a Certech single rear 88mm turbo)
Cheers
Chris.
Cheers
Chris.
#40
Former Vendor
because he is running the basic sts rear mount system
