Anyone want a transmission that will hold your F/I, nitrous power???
#61
AtomicC6 and I got the cradle in today. I had some serious trouble getting the passenger side axle in the last time I put it in and when I looked at it today and noticed that there was no chamfer cut in the end of the axle. I took my die grinder and cut it in there. It slid in like butter this time. Once we began bolting the cradle in, we discovered that the Pfadt adapters had to have the bolt head side facing the outside, otherwise they wouldn't clear the cradle, so we reversed the bolts and nuts.
After all of that, I began checking the exhaust clearances. It doesn't fit!! UGH! I haven't decided what I'm going to do about it yet. I have cut and welded pipes before, but I'm afraid it will take too much trial and error with stainless U-bends to justify the expense since they're so expensive. I have a friend that owns an exhaust shop. I am going to call him to see what he can do for me. Until then, I'm stuck.
#62
Need some pictures
I'll be doing the same thing in the fall when I get to that part of the rebuild.
I bought a set of Magnaflows that come in (3) pieces like the borla stingers, so hopefully they'll have enough adjustment in them to work.
What did you do with the brake lines ? I was thinking of drilling a couple of holes like the factory did to hold the line in place.
I'm most interested on how did the cooler hook-up. I'm not sure if I'm going to need the cooler since I won't really be tracking the car, except to figure out how fast it does a 1/4 mile.
#63
I have heard that the easiest way to fix the exhaust problem is to cut it right behind the 2-bolt flange where the over axle pipe bolts onto the x-pipe. cut out a 2" section from there, weld the flanges to the new part of the pipe, then cut the pipe at the peak of where it goes over the axles, and weld in that 2" section of pipe that you just cut out, and weld it in at that spot. Basically extending, and widening the "U" shape going over the axles.
#64
Need some pictures
So you want pics of me throwing stuff because my exhaust won't go together?? JK
I re-bent them a little by hand so they don't rub anything and they're fine.
I ordered the cooler and they told me that it won't be here for 2 weeks, so I looped the output of the pump back to the input of the trans and will put it in when it gets here. I was hoping to drive it, but I have to figure out this exhaust mess first.
#65
And yes, I'll get pics.
#66
More info here.
http://forums.corvetteforum.com/c5-f...de-a-c5-2.html
#67
Thanks man! You're awesome. I was trying to sleep while thinking about it and after not being able to sleep, I went back out and took a look and was thinking that I could extend the hoop above the axle to add clearance. I got on the computer and coincidentally, I got a PM from QuickZoh6 and he told me that he was told the same thing by a shop. I went to Dallas Performance and bought a 90 degree bend and started chopping up my exhaust. It's going to take some work, but I'll get it done and pics will follow.
#70
Yesterday, I cut the driver side pipe where it goes over the axle and tacked a test section of mild steel in line. After a test fit, I decided it needed to be a bit longer, so I cut the stainless and welded it in. Then I cut the flange off up front along with some extra pipe and rewelded the flange back on. It fits now up front, but I had to re-clock the pipe away from the cooler and lines on the diff. This forces me to chop the rear flange off the last piece in the rear and re-fit it as well. I took some pics, but it will take some time to upload them and I will do it when I get time. I want to focus on the task at hand. What I'm thinking of doing is cutting the flange off along with a couple inches of pipe and then having the other end expanded at an exhaust shop so I'll have some room to adjust before I weld it. That will provide a better guarantee that it fits better. More coming soon.
#73
Ok. I got the exhaust system worked out. It was not too bad. The driver side doesn't have much room between the exhaust and the heat exchanger for the differential, so I'm going to wrap the exhaust and lightly modify it in that area. I cut the hoops and extended them. I can weld mild steel fine, but not so well with the stainless wire. Part of it may be because I use gold gas instead of straight argon. I tacked the passenger side together and am going to my neighbors house to TIG weld it so it'll look nicer. Also I sold my old tranny to Rick aka. ragtopws6. He was nice enough to send me pics of the carnage.
Here's the exhaust hoop uncut.
I cut the hoop
You can see how close it still is, but it is rigid, so no risk of interference here.
Here's how close it is to the heat exchanger.
Here's some pics of the notorious 3rd gear carnage that happens due to having to multiply torque through the cluster.
Looks like these gears are in need of a good set of dentures.
I cut the hoop
#76
The exhaust is all welded up now and everything seems to fit just fine. We went back over my "blobby" welds with a TIG torch without feeding any more rod in and it looks much nicer. I have some other things that I need to address while I have the car apart, so after I take care of everything else, I'll button it all up and get my baby back on the ground where it belongs. I'm going to AtomicC6's house this weekend to change out a wobbly balancer on his TT monster, so I won't be back on this project until next week. I will report back with more pics as things come together.
#78
St. Jude Donor '08
Looks great Bret!
On another note, I drove through Forney twice yesterday going to and from Dallas Performance. I was thinking "damn he needs to get that car on the road so I can see it fly past me" LOL
#80
Thanks Tony!
