ls2 intake manifold price and improvement
hey guys is 250 a good price for a used ls2 intake manifold...
Also what is the gains that I will see from it and the TB
Also what else do I need to install it on my ls1 i know i need the harness is there some water rerouting lines that I need.
Thank You,
Edgard
Thank You,
Edgard
The prices are definatley cheaper than an ls6,& for fi u will see improvments ask traci @ rev extreme about going to an ls2 ,ur gonna need a map sensor harness that will now plug into the front instead of the back & ur gonna need an ls2 fuel rail,also the ls1 injectors are longer than the ls2 injectors ,,kateck makes an adapter for this problem,I have been there done that,pm me if I can help u in anyway
Personally I'd stay with the LS6 manifold - I don't see much of an improvement over the LS6!
As FSUFORVER stated there will be additional harnesses needed - especially the Injector Harness from LS1 to the EV6
Thanks,Matt
Thanks,Matt
SpeedwayC5Z06 (10-26-2015)
I guess everyone has there own opinion,I know that traci @ rev pulled an ls6 off a charged car & put an ls2 on put it on the dyno & gained respectable #s out of the ls2,if. I am not mistaken the tb on the ls2 is how much bigger than ur ls6 tb,o that's not saying bigger is better ,but if I. Remember correctly that's definatley helping ur motor breath ,for my 402 it is, call traci he's a straight shooter & a standup guy 1 941 753 5255. Sales@revxtreme.com, ask someone who's done it
I've read where the manifolds are close until you get in the upper RPM's and the LS6 takes it. I've also read where a ported LS2 will make up that loss and then some. Never seen a comparision on a F/I car, but I can tell you that I'm quite happy with mine.
Take a look at the huge gains we saw from swapping out an LS2 intake on this engine to a FAST 92mm. Bob
http://www.exoticperformanceplus.com...Car.php?car=29
USMC (retired)
