What do you guys do for SC tubing scraping ground?
I have a Procharger and lowered Z, and the intake tubes right behind the airdam are only about 1.5-2" above gound and scrape when I come in driveway. Should I just go slow and not worry, or is there a fix besides raising the car up? Teflon skid plates, etc?
St. Jude Contributor
I cut my main tube and moved it up as high as I can - it helped but it still touches some times
So I have plans to make a skid plate for it, I like your teflon Idea, I was thinking a piece of aluminum held on with hose clamps - I do think it;ll work fine and easily be replaceable
I my opinion raising the Vette is not the option -
Thanks,Matt
Thanks,Matt
I was thinking of moving my battery to the trunk. Maybe anything else that could be relocated also. I don't mind raising the car back up to its original ride height as drivability is more important. I need to enjoy the car and not cringe every time my front spoiler contacts a speed bump or hump in the road. Hell I cant even get in and out of my drivway very easily any more. I may try all of the above suggestions and possibly consider getting a shorter radiator and raising my cradle back up. I know that I am going to have to do something before the really hot weather gets here any way. I may be trying to seal every thing off in there so that air has go through the intercooler and radiator instead of around it as it appears is possible right now. I will post up when I get it done show some pictures.
You really should be able to shorten up the ;plumbing and raise it nice and tight against the undercarriage. What type of kit do you have exactly?
Procharger, I think it is the standard kit, was on the car when I purchased.
It looks like the lowest thing on the car are the 2 tubes that come from the intercoolers on the outside corners going to the middle to the intake. The tubes are black, maybe hard plastic, or cast metal.
You can shorten up the top rubber coupler that comes from the blower to the "T" shaped metal tubing that goes to each of the intercoolers. Once its shortened up you can push it upward higher and get it more off the ground.
