A&A Corvette Performance:Forced Induction Q&A thread
#201
Former Vendor
Location: Oxnard SoCal www.aacorvette.com www.superchargersuperstore.com
started car today ran find 5sec. later i could here a louder wine from charger , took belt off turn by hand ,can here small grind .i have A&A kit. should the pulley spend freely or should it have a little drag. i live near tampa fl. is there a shop here i can take it to to have it checked..
#202
NON Underdrive balancer Procharger Belt size
I am trying to find out my correct belt size for a 4.25 pulley. I found some info before but apparently it was wrong I do NOT have a underdrive balancer, I DO have the new style bracket and it is a 4.25 pulley. I have done alot of searching and had all kinds of conflicting information. I would like to get this right this time since it is a pain to remove the bracket and install a belt. maybe somebody is a better searcher than me
#206
I have a v-3si kit with a 3.8 pulley. Anyone have problems with tuning it with the 60# injectors? I ask because the tuner I am going to says the car runs well while in boost but if not in boost its not pleasant. Seeing about 7 lbs of boost. He says I should go with 45# injectors instead. The only other mods i have are 1 3/4 l/t headers and a monster clutch. Another 500 bucks seems like a kick in the nuuts especially if no one else has had problems. Thanks for any input.
#208
Former Vendor
#209
#210
mr.632, Take a look at Summit Racing #sum-c2501. I just installed one and it does not hit the blower bracket. However, I shaved about .200 of the back of the bracket below the the idler pulley adjacent to the balancer just for added clearance. I haven't put any miles on it yet, but it spins perfectly with no wobble. It's rated to 12,000 rpm. It is an 8 rib balancer but you only use the forward-most 6 ribs. Width and dimensions are the same as factory. I used an ARP bolt @ 240 lbs. Check it out and see what you think. Rod
#211
By the way, I must give a shout to The A&A guys. I called over there and asked a bunch of questions to do this job. They were not getting anything by me doing my own work, but took the time to walk me through the rough parts of the job. Thats why they are so respected in their profession. They are the only shop I will ever take my vette to. Rod
#212
Former Vendor
#213
Looking into an AA kit but of course budget is such an issue at this time it is still in the planning stages. I currently have a stock 2000 C5 A4 with about 85k miles but will end up at about 90-95k miles when I am ready for this. Any maintenance tips? New springs/retainers? And for those who will chime in regarding the A4, that is also in the plans to be built by RPM. Not looking for max power just things I should do in order to be safe with the kit.
Ca means i gotta go carb legal which AA seems to have so it is pretty surefire i will go with them.
I heard they have refurb complete units at times for quite the bargain... Steve if you guys do please let me know asap, I can finance that for now until I have time to to install it myself or save to pay someone to install it. If there is a wish list to be added to please add me. Thanks please be friendly as I am new to the SC and vette scene.
#214
CF Senior Moments Member
1 Post
I've been extremely happy with my A&A SC in my 2000 vert 6spd!
V2 Si type car made around 590RWHP LS6 cam stock LS1 heads / crank / pistons etc.
I've been slowly gathering stuff and aquired a used (13k miles)
SDPC LS2 block bored to 4.005 with
Diamond forged pistion -14cc
Crower forged I-beam rods 6.125
Eagle forged 4" stroker crank.
ported oil pump
GEN IV front cover with cam sensor
LS6 valley cover
LS2 timing chain lifter trays
COMP 850 lifters
stock front crank pulley.
AFR 225 Heads 74cc heavy duty springs
Yella Tera 1.7 roller rockers
I have a choice of the cam that came in the forged engine - or one that I bought seperately (at an earlier time)
Forged engine came with a Cartek 5x 244/252 .602/.612 114LSA
Cam I have (new never used) is 224/232 .59x/.59x 114LSA
So what cam will be best for this setup - being mainly a daily driver and used for fun trips - love third gear pulls - but hardly ever do standing starts for fear of breaking my poor old tired drive line components or trans.
What is the difference 116LSA vs 114LSA - I saw a post that mentioned you guys don't advise going lower than 116LSA?
ported oil pump
LS6 valley cover
COMP 850 lifters
#215
hp ratings?
Just a question? How are you guys getting 550 plus to the rear wheels? I was told that I only got 480 to the rear. I am not complaining because I am happy with my A&A SUPER CHARGER and the installer. Those number sound inflated. What should I be getting? My car is an A4 and pretty much stock.
#216
Former Vendor
#219
1 Post
Change from LS1 to LS2 ?
My current A&A Vortech is on my 2000 LS1 6spd Convert and I'm loving it! Been running it since around December 2008. This unit did include the "new" ram-air intercooler that you guys had just released back then.
I have a forged LS2 402 ready to swap in and wanted to ask a few questions.
1) Will the brackets / everyhting switch over for the A&A system?
2) What is the HP limit I can expect with the current injectors (?60lb?) and Vortech (the self contained one with higher efficiency rating (??Q-2??) unit I currently have? I think the pully size is one smaller (?3.5 or 3.6?) that should give around 12- or 13 lbs boost.
I can't find my original sheet with the information :o
I was hoping you might be able to look it up possibly?
#220
Former Vendor
Burk Bartels
Burk Bartels
2. If you have the S-Trim, you will max out on a 402 around 650-675. I can't really say how much boost the 3.6 will make on the motor, because of variables. I would think it would be around 8 or so on that motor with headers.
3. You may want to remove your phone # and address from the post.
