A&A Corvette Performance:Forced Induction Q&A thread
#1001
Platinum Supporting Vendor
__________________
Thanks, Josh Dodson
PLEASE TAKE A MOMENT TO VISIT OUR NEW WEBSITE AT WWW.AACORVETTE.COM
NOW PARTNERING WITH AFFIRM TO OFFER INTEREST FREE FINANCING!
A&A CORVETTE PERFORMANCE
477 LAMBERT ST Ste A
OXNARD CA 93036
(805) 278-4107
Instagram @aacorvettesuperchargers
• Facebook.com/AACorvette •
Thanks, Josh Dodson
OXNARD CA 93036
(805) 278-4107
#1003
Received 1,254 Likes
2016 C5 of Year Finalist
Self contained Vortec Supercharger oil
Josh--We had a little problem the other day at the shop. We could
not locate the small container of oil used in self contained
Vortec Superchargers. I have a tapped in the oil pan supercharger and I thought it was all right to use a 5-10-20 synthetic oil.
We finally found the little container of oil that came with the
self contained unit. But.... if we had not found it. What would
you do???????? Could we use any synthetic oil???
Thanks.
Thanks.
#1004
Thanks.
Thanks.
All V3 (self-contained) headunits require the Vortech V3 oil. It is some kind of synthetic oil they spec.
If you are using a (engine-oiled) headunit then it uses which ever oil your engine is using and can be regular or synthetic.
#1005
Have a different bearing than the engine oiled supercharger.
And the self contained unit needs a different blend oil.
Is that what you were conveying to me????
Thanks again, Josh. I am trying to make sure this is not a
marketing answer. (from Vortec)
Happy Thanksgiving.
#1006
just purchased my car and it has an A&A v3 kit already installed and i have an annoying squeal from the belt or a pulley. is there any "common" pulley that causes the issue because i go and just replacing them all?
#1007
Would be best to call in and speak to us over the phone and we can help you diagnose it. 805-278-4107 shop
#1008
Finally got my car's tune and fuel systems sorted.
Turns out with my cam and other mods, I needed an auxiliary fuel system, 100lb injectors, and the racetronix pump was bad as well, replaced it with a LG 255lph pump.
V3Si, on an old Mustang Dyno nicknamed "the heart breaker" it's at 551 at 6700 rpm, the tuner said that on a dynojet or dynapack it's a 625hp car easy depending on the correction factor, putting the engine at 650-700.
HP was still climbing at 6700 and we stopped as I'm on the stock short block, clearly I have the wrong cam in the car for a S/C application.
I guess a shortblock will be on my short list for the future. I hope to get a few 1/4 runs in at island for a baseline before they close.
Josh@AandASuperchargers (11-30-2017)
#1010
#1011
#1012
Hello
I am going to forge my stock short block. I am using a ti trim with a 3.4 pulley. What are some smaller pulley options to increase boost? Block is an ls6, stock cubes.
Thank you
Thank you
#1013
https://vortechsuperchargers.com/col...ant=7811183297
#1015
It's a good idea to go 8-rib with 2nd drive combo when you start cranking the power up past 700rwhp or higher. If you are forged engine you will probably end up with a big Ysi headunit and that will need the bigger drive system. Then with a Ysi you will have enough blower to make up to 1,000 rwhp.
#1016
Pinging Josh!
Looking to replace my plastic intake dongle with the straight pipe, already have the SC radiator and SPAL fans. - anyone know which one fits/is correct?
A&A sell a kit?
Thanks!
A&A sell a kit?
Thanks!
#1018
We don't have a drop in kit. Most guys will fab up something to fit a 4" pipe in there.
#1019
I bought one of your kits and I don't know if I'm putting together IKEA crap or a supercharger kit. YOUR INSTRUCTIONS SUCK!!!!!!!!!!!! for 5K THIS CRAP JUST SUCKS!!!!!!
#1 put the instruction in the box. Your customers spent 5k and having paper instructions really makes a difference.
#2 you need to do without the pictures and write this thing up correctly. I kept having to go back a step or two.
#3 make sure all the bolts and washers are in the kit. Mine was missing the bolts and washers to mount the intercooler. Not a big thing but for 5k it should have all this.
#1020
All I can say after speaking to Andy and his rude comments. I decided to buy A&A because all the stories about the other company’s setup and customer service. I can’t see the Other guys customers service be any worse than A&A’s. This guy is at his own level! He agrees that the instructions are not up to par. Hey it’s just a $5k kit. Lolol
Don’t worry about standing behind your product that you sell. I found another BAP locally. I’ll get with Kenny bell myself.
