Want to Buy Pulley for Vortech Supercharger
Looking for a 28 tooth pulley for my vortech v2 sq supercharger.
Does anyone also have an upgraded jackshaft pulley needed for this?
That very well may be the guy I flipped out on if he was rude, if hes not rude normally then no it probably wasnt him??
Steve is there a way you could find out from your buddy what I would be able to do with the serpentine pulley and crank pulley? I already know I will be running the 28 and 32 SC and JS pulleys
Former Vendor
Location: Oxnard SoCal www.aacorvette.com www.superchargersuperstore.com
Go smaller on the cog pulley attached to the supercharger
Go bigger on the cog pulley attached to the jackshaft
Go smaller on the ribbed pulley attached to the jackshaft (3.6")
Go bigger on the balancer
Or do all!
The 3.6" ribbed on the serpentine side of the jackshaft probably had the snout of the pulley machined down some, so a 3.33 off the shelf from Vortech will have to be milled down. I would do the 2 cog pulleys you are talking about and go from there.
Steve thank you very very much sir.
I will do as you say with the cogged pullies I have and then go through you to purchase the other 2 if I decide I need more boost.
Thank you sir
Thank you sir
To turn up the boost, you can do the following:
Or do all!
Or do all!
