Belt tensioner bending/ breaking problem with newer A&A kit with an YSi
not nice but we all break stuff on our kits!! even other brands these kits are a amazing what they can do lots of hp 800-1000 stuff breaks even ecs! and its not fun or cheap! so lets all play nice were all in this together (boost addiction)
Actually 756@15 psi on a mainline dyno so I'm high 800's at the crank. I couldn't boost over 15 psi do to belt slip. This was before the ECS bracket and flip drive. So I think 20 psi would get me well over 900 rwhp
Received 1,762 Likes
Brandon, That thing is moving at whatever h.p. I am hoping that my parts dont go south on me man. But I do love this YSI unit just like the F1 unit that you have these beast dont stop pulling until you let up on the right foot. Man if you are ever out this way call will go out and eat.
That is why they weld the tensioner once you go to the flip drive because now you can tighten down that belt and don't need the automatic tensioner anymore except to be an idler.
The flipdrive may actually put more strain on the tensioner since you can now really crank down the manual tensioner since the drive belt no longer hits the other accessories.
St. Jude Donor '09-'10
Premium Supporting Vendor
Location: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Received 1,085 Likes
Although possibly uncalled for is true, the rest of your statement is 100% FALSE.
ECS has been in the supercharger game from day 1 along with A&A, our kit has been THE pioneer of HD supercharging performance, not the other way around!
ECS has always focused on performance first, not selling a cheap kit first, hence why you do not see posts with HD tensioner upgrades for the ECS kit etc. It is also the reason why we have lead the way in every type of supercharging performance records from as far back as 99/00 when we were the first shop to break 500rwhp supercharged, to having just about every stock bottom end record, let alone our hard core cars.
Get your facts straight boys...
OP, go with Arun's HD tensioner, he'll fix you right up.
We have also sold many of our tensioner assemblies to A&A owners who cut the bottom of their SC bracket off to adapt to our set up.
__________________
C5/C6 and C7 Supercharging Specialist
ECS Supercharger Kits / Mantic Clutches
www.EastCoastSupercharging.com
Facebook Page
ECS YouTube Channel
Facebook Page
ECS YouTube Channel
#33
Here's my attempt at some instructions-any questions just email, pm or call me.
First off remove the the old tensioner and pulley-use the new shorter supplied bolt and bolt it on the new HD tensioner.
Now bolt on the adapter plate to existing hole and line up the plate to the bracket.
Now bolton the tensioner-use the other round spacer on the opposite side of the tensioner.
Get everything lined up and drill the top hole in the adapter plate out to 5/16 and tap to 3/8-16. Install the last bolt-tighten it up and your done.
#34
looks easy to me! if you never tapped aluminum oil helps the tap. don't force it work it slow and back it out if it gets hard! clean tap shavings out and add oil start tapping take your time
#36
Have these issues been solved?
Im considering a change.....but wanted to make sure these problems were addressed.
#39
http://forums.corvetteforum.com/c5-f...e-enter-2.html
Wow congrats, that must of taken a while to find.
That was a bad batch of HD idlers so yes.. which is why we make them in house now, and that customer received them for free.
I believe what Jay was trying to convey, but unfortunately put a spin on it that apparently disturbed you, is that all of our HD 8 second cars run the same set up as our stock engine customers. Or to be more comparable, a common street car with an eight rib belt, has the identical set up to Digivex's 3600+ car that has ran 9.3's. Take the ET out of the equation since some of that is from it being a power glide car, but the point is that there were no additions to his base kit necessary like tensioners-head units and so on to not only run those times, but hold steady boost and be consistent with the ET's too.
Again, all without upgrading which costs far more then purchasing it ready to go from the start.
That's just one example, we have 100's, and more importantly we have cars that compete nearly every weekend that way. Their point leads can be followed at ECS Corvette challenge web site in my sig below. Proving their reliability in the harshest environments, and where a bad day cannot just not be discussed like at a rental.
#40
Nah it was an ez search...modern search engines
For history sake did you completely design from scratch your system and do you make a majority of the parts in house. If so how long would it take for parts should a problem arise? Im considering your product for a future build and like to know history and how you will treat me after the sale.
