View Poll Results: Best Drag Radial
Nitto 555r
5
7.35%
Mickey's
49
72.06%
M and H
10
14.71%
Toyo Proxes TQ
4
5.88%
Multiple Choice Poll. Voters: 68. You may not vote on this poll
best drag radial for a 800hp plus
CF Senior Member
Thanked 0 Times
in
spinmonster knows best he has tested them all!!!http://forums.corvetteforum.com/c6-t...-solution.html
Hardly on either account IMHO. But at any rate, the OP needs to provide a lot of additional information before even soliciting tire ideas. Items such as rim diameters,Rim Width,Mini tubbed,Willingness to run a 28" tire etc. This on top of typical driving (No Rain?) conditions,Driving style (Straight line light to light,Drag,Johnny Roadrace) and preferred characteristics of the overall wheel/tire combination.
Denscor,
Give us your detailed driving specifications!
Based on the info so far, I'd have to choose M/T drag radials.
CF Senior Member
Thanked 0 Times
in
The car is not my daily driver. It will be taken to the track maybe 4-5 times and its more of a weekend toy.Its a 6 speed car with a spec stage 3 plus clutch dte strut brace built rear end with both output shafts upgraded. The motor is a LS7 with a f1 pro-charger with 14 psi of boost. I have read bad stories of what can happen on the street if it get loose with street tires.
CF Senior Member
i run M/T slicks at the track. 26x11.5x17 on stock wagon wheels. i can make it hook with a 1.41 60'.
i have had nitto 555R and those were horse**** for hooking. at the track or on the road, i didn't like em. they lasted quite a while though and they drove fine in the rain, so i will give it that.
I also have the BFG drag radial and those were awesome! hooked very nicely on the streets and decent as well at the strip. in fact, i road raced on them once too and was not to shabby. they lasted about 8K miles b/w track and street use. worked well in the rain as well, def can't go wrong with them!
Now i am running Toyo RA1s and they seem to be awesome! hooking 700rwhp just fine. no track results yet though. i drove them in the rain and they were pretty good. no hairy issues...
ps, all the drag radial sizes i was using was 335/30/18.
Aj
Aj
CF Senior Member
They`re a nice tire at the track... I didnt have much luck with them on the track... I did much better with the old Hoosier tires I got from 4drush... We are looking at Drag radial specific tires...
CF Senior Member
I like to run the M/T @ the track with 17psi and 25psi on the street they really do well in the curves
CF Senior Member
Thanked 2 Times
in
For street driving they arent worth wrecking the car with them on in any kind of aggressive handling situations. Im guessing you guys dont drive your cars anywhere near their maximum handling capabilities with drag radials on which is a good thing.
CF Senior Member
I have the nitto 555r and a set of mickey thompson drag radials both in 305/35-18 sizes. In back to back testing the MT tires perform better on the street...I haven't tried them at the track. As for handling the curves, even with low tire pressures they seem stable to me.
For 800+ hp I would recommend the MT 345 or the new nitto nt-05r
#33
#34
Edit; Post up on the performance section and get the opinion from the real gear heads.
#35
CF Senior Member
Thanked 0 Times
in
How did the M and H do?
#36
CF Senior Member
A friend of mine ran the Hoosiers on his Z and lost it on the 1-2 shift, dam near totaling the car out. Runs the 325 M/T ET street radials now.
#39
CF Senior Member
Thanked 0 Times
in
I have the Mickey Thompson Drag Radial II, 305/35 18 and they work great. Awesome tires and hook up awesome. Believe it or not they last pretty good as well.
My track tires are Mickey Thompson ET Street 26x11.50x17. (1.46 60' ) I see a pattern here.
#40
CF Senior Member
The only reason why the Mickey's have it is because they've never ran on the Hoosier drag radicals. The Hoosiers will give you poor mileage on the street (no rain),but they will hook better than "ANY" other drag radical when comparing them to a comparable tire size.
I think this thread is full of people That are on Mickeys band wagon... I`m going out on a limb and say 90% of the people on this thread have never tried an M&H tire....
