fuel pressure regulator location
Hey guys I am just buttoning up my supercharger install this is on my 97 that has a return system,do I put the fuel pressure referance line before the charger by the filter? or on the tube after the intercooler directly on the inlet tube?
I don't want a boost leak so I just want to make sure where to put the regulator vacumme line.. Thanks guys
Again this is on the 97 that has a return system
Are you talking about the vacuum line that attaches to the fuel pressure regulator? If so, it needs vacuum coming from the intake manifold. That is usually tapped into through the brake booster line.
Yes I am talking about that one .. It's getting tuned tomorrow so I need to know easiest place to install, when I got it had just a cold air intake and it has a rubber grommet and a small plastic elbow in the powerduct... Anyone have a pic as to where they put theirs? Time crunch
