MVP'S 2002 Supercharged ZO6 Build Thread
ISIS SUCKS FAT CHOAD
Just went a head and ordered the last set of Yella Terra 1.7 non adjustable roller rockers that Hinson Supercars has in stock. Glad I got em because I didnt want to wait for them. Now its time to wait on the thread where someone has a brand new set for way less then what I just paid for mine. cant be having no valves fail again. LOL
AKA "The CLOWN"
I think you should be a great giving person and donate those to my charity, the "want to go fast, but ran out of money for toys organization" all proceeds go to my car fund!!!! It will be a tax deduction at least!!!
Hope those work out nice for you
well heres the lastest update on my build. Got the Driver side head off tonight and the good news is if I wanted to I could replace a piston and be back on the road. However, I already have the 402 in the works.
heres some pics of the damage.
Ok so new yella terra shaft mounted roller rockers came in today. My question is do I use the stock bolts to mount these or was there supposed to be a set of bolts?
Just a lil update. Not that things are moving incredibly fast. I got the engine out and it's pretty much sold. Waiting on payment. Once the buyer receives the engine and is happy with it, I will be utilizing those funds to aid in the purchase of a new crank and rods, main and head studs and cam Ect. The cam specs will be 240/248 .609 .615 lift with a 110 ICL and a 114 LSA. With racetronics 120 LB/HR fuel injectors. Ill be Adding a second nozzle to the AEM meth kit, I will be running the T trim (unless it sells in which case I'll be upgrading right away to the YSi head unit) and 8 rib with a direct drive (until I can buy a 10 rib setup). I will also eventually be upgrading to a tripple disk (again when I can afford it).
#38
Here's a little update. I spoke with Charlie at RPM and he said my engine is complete and ready for pickup.
I'm going to try and head down there tomorrow. If i cant make It down there tomorrow, I will go on friday. I'm excited! :-D
