You guys about ready for my build thread??
#43
I can hit the pudding progressively and roll into the shot, so no plans for any more stages. I plan on starting out with the 200 pills and seeing where I'm at. I've got pills for up to 300.
#50
Thanks man. It's only about 2/3 done from what it's going to be when I'm done with it. Got to ride in the TT Gallardo while I was there yesterday .
1200RWHP with 1300RWHP worth of pills in my pocket.
If I were a die hard racer, I would be face plating the trans, doing a slipper clutch and a good 2-step. I'm trying to find that balance between having a car that performs decent at the track and a sinister machine on the street.
I will be wiring the hot through the stock fuel pump relay. Engine dies, kills the fuel pump relay and power to the dedicated system. I'm still running away like a bitch!
#55
Received 1,762 Likes
#57
Fuel pump relay is activated by the ignition switch, has nothing to do with engine running otherwise the engine won't start.
#58
Key on, fuel pump pulses for ~1 second. You start the car and the fuel pump comes on. If the car dies, you hear the pump for 1 second and it dies. It's a safety feature in case you get in to a wreck and the fuel system is compromised.
#60
Life is getting a little boring these days. Everybody knows what happens when BlownBlue gets bored!
