Dual DW pumps in RSI Hanger...
check this out guys this was done on a 4 cyl DSM. They do not provide information about base fuel pressure or anything but we all know the lower the fuel pressure the more you will be able to make as long as injectors are big enough. From looking at this results we should be able to make 1200 WHP with some ID 2000 without issues maybe even more. http://www.dsmtuners.com/forums/bolt...rformance.html
Sure looks promising, but you know how this stuff goes. Need to see RESULTS.
That said, I really can't see why this wouldn't support more power or why the wiring would be an issue.
Yea, you should not run into issues with the current draw on the factory wiring due to the relay circuit feeding power directly from the alt. to the pumps.
You can't use the results from a 4cyl as a guideline. Like you said, you don't know fuel pressures or the efficiency of the motor. We have a general idea but I feel like twin DW pumps should deffinately be good for over 1000rwhp.
Nice talking to you today Chris. Great customer support! RSI didnt even call me back.Will makes good products but there support after the sale or trying to get the status on items is very poor. Also would like to thank BLOWNBLUEZ06 stand up guy good person and helps anyone! Ill make a thread on my update on what failed on my RSI system. Could have been alot worse up high in the rpm's and went boom bitch.
Hey Chris I have the DW301 Pumps and working perfectly
Thanks..
good thing you cought it.
Bret is da man
#36
I know this thread is alittle old.I did the same thing,I put 2 DW pumps in a RSI hanger,I had to grind one of the hold down brackets alittle,But its working great so far.
