Auto Swap Thread
Old Mar 17, 2012 | 10:55 PM
  #181
Chris Stewart's Avatar
Chris Stewart
Originally Posted by rodney@rpmtransmissions
I tried that once.... hits the shifter box on the manual set-up. Its a lot easier to remove it with the drivetrain removed from the car.
Ok that's a pretty good reason.
Old Mar 18, 2012 | 10:09 PM
  #182
corvette8189's Avatar
corvette8189
Well gave the car some hell this weekened, and it gave me hell. Dropped the shifter in 1st and then tried to go up and nothing. I believe the shifter linkage is messed up. It will go from park to 1st but wont go 1st to park.
Old Mar 19, 2012 | 11:31 PM
  #183
a/c man's Avatar
a/c man
now that you have a auto r u ready to race me
Old Mar 19, 2012 | 11:37 PM
  #184
corvette8189
once I get it back together I'll be ready
Old Mar 20, 2012 | 12:07 AM
  #185
a/c man's Avatar
a/c man
just for fun I wont spray if you wont spray
Old Mar 20, 2012 | 04:30 PM
  #186
corvette8189
im gonna give it everything it has
Old Mar 30, 2012 | 05:14 PM
  #187
NEMESISVETTE's Avatar
NEMESISVETTE
Any update on this? Im about to do this swap and really need all the info I can get. This has been a helpful tool thus far.
Old Mar 30, 2012 | 06:57 PM
  #188
corvette8189
she runs good, if you need anything or have any questions just pm me.
Old Mar 30, 2012 | 07:01 PM
  #189
corvette8189
well dont use a broken shifter linkage, this will happen
as you can see got a new one but the mounting tabs are different. Who knew they would be different. So i ordered the one i need should be here tomorrow. With any luck i should be good to go.
Next is to track tune with Brett and bust off some low low 9's
Old Mar 30, 2012 | 07:30 PM
  #190
4DRUSH's Avatar
4DRUSH
Good luck
Old Mar 30, 2012 | 10:04 PM
  #191
a/c man's Avatar
a/c man
Originally Posted by 4DRUSH
Good luck
good luck low 9s are not easy
Old Mar 31, 2012 | 08:25 AM
  #192
baezi z06's Avatar
baezi z06
Good luck
baezi
Old Apr 4, 2012 | 03:18 AM
  #193
NEMESISVETTE
This is what im running
http://www.powertraincontrolsolution...anscontrol.php
with rpm's harness
Im in the middle of a Auto swap. Im using this thread as a tool. Can you post link to the RPM harness I need? Also im going to copy you and use that PCS TCM-2000 like you did...Any advise? I have the Auto wiring harness complete front to back.. What else do I need wiring, or electrialy speaking?
I made a thread here http://forums.corvetteforum.com/c5-t...ap-2-guys.html
PLEASE HELP me with advise.
Old Apr 4, 2012 | 09:22 AM
  #194
C5 Pete's Avatar
C5 Pete
AMP Racing
2023 C5 of the Year Finalist - Modified
2017 C5 of Year Finalist
St. Jude Donor '09-'10-'11-'12
You should call rpm as they don't list the harness on their website. They can also help you with all your wiring questions.
It seems a lot of people get anxious when wiring situations come up - myself included. As it turns out, with one phone call to rpm, all my questions were answered. I got the harness from them. The only electical work needed is to take the rpm harness and wire it into the PCM. It's not as big a deal as it seems.
In your case with the stand alone controller, I have no idea how it works, but I bet the op will be happy to help.
Good luck. Its a fun conversion.
Old Apr 4, 2012 | 06:39 PM
  #195
corvette8189
With the pcs controller, u do not need the rpm harness or any other wiring harness. The pcs has there own harness you need.
The wiring harness looks hard but most of the wire you wont use. No other wiring needed.
All you have to connect is a 12v switched, ground, tps, tach, and vehicle speed sensor. I mounted the controller behind the pass seat and ran the wires through the e-brake hole.
Old Apr 4, 2012 | 06:46 PM
  #196
NEMESISVETTE
That is some great information thank you. Do have any part numbers for the harness I need from PCS TCM
Old Apr 4, 2012 | 06:50 PM
  #197
corvette8189
here is the controller
I bought everything through RPM, give Rodney a call.
To Auto Swap Thread
Old Apr 8, 2012 | 08:31 PM
  #198
NEMESISVETTE
Originally Posted by Capthuff
3). The purple and yellow wires from the clutch don't have to be pulled out, as the new harness will have the proper wires that attach to the neutral safety switch.
Thanks.
Originally Posted by ajg1915
1.)
3.) Don't touch the wires inside. "C146" connector will plug into tranny harness connector and run back to tranny switch.
Ok I have the Auto wiring harness ran and all my Auto parts. Got my manual brake pedal out. sucked but got it out.
Im unsure what I need to do about the clutch safety switch? So I have to run those two wires back to the transmission? Can I loop them? cancel them out?
Old Apr 8, 2012 | 09:47 PM
  #199
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Which way are you going auto to stick or stick to auto ?
If you're going from stick to auto. The wires should be in your tansmission harness that run back to the safety switch on the auto trans.
The additional harness that you get from RPM "C146" would give you the other side.
If you jump the yellow and purple wires together you car can be started in gear and that could be dangerous.
If you're using a transmission controller, you make up two wires (yellow and purple and run them from the safety switch inside the car out to C146 as a quick fix to your problem.
Old Apr 8, 2012 | 10:06 PM
  #200
NEMESISVETTE
Thanks for the response. Keeping this thread alive.
Im going from Stick to Auto in my FRC. I got the full harness from a same year Auto car. My manual wiring harness did not run to the connection of the swith under the clutch pedal. So are you saying I do nothing with the wires that went to the switch under my clutch pedal becouse the Auto wiring harness gets its safety start another way? Again thanks for your brain cells on this.
