Auto Swap Thread
#241
As I recall, it's actually a snap that locks onto the pivot that sticks out from the shifter.
I don't think it's easily repairable.
#242
I been following this thread for a while as I had an auto swap done on my 2000. Had problems initially with the car not shifting ONLY at wide open throttle. Turns out the differential was toast. Teeth on the gears were broken and the diff itself was broken (thanks tx speed/dte). Also the trans had a hairline crack on the input drum? I think is what I was told. Everything is back together and the car feels pretty strong now! Can't wait to see some numbers
#246
i´m having trouble though
i need to check the PCM, plugs and all wires from PCM to Transmission (4l60e)
i´m getting pulse (rattle) to the 1-2 solenoid and the transmission is not working correctly, it doesn´t take the 1st gear or like it stuck between gears or in two gears at the same time.
and when i put it in D it starts in 4th
in 2nd it starts in 2nd and 3rd is just 3rd
but i can manual shift it from 2nd to 3rd and 3rd to 4th
the valvebody was take out and the solenoids work correctly on the table , so it is like the problem is in the harness or PCM
i rechecked all wiring i installed , got a RPM jumper harness and then Reflashed the PCM to tell it it´s AUTO
i don´t have a service manual , it´s not sold here in Iceland
i need to know what signal i´m looking for from each pin/wire
if you don´t know what i mean , i mean like what pin/wire sends ground signal , what signals V and what signals pulse.
do you guys have any chart what so ever you could send me camarof1@visir.is or maby know where i can find these informations on the web.
thanks
Baezi
#247
figured out my problem
did a wrong Reflash method...
i just changed my current manual file whith auto compare file but it needs to use a stock auto file and Rewrite it
so i bouhgt a new credit and used a 2004 stock auto file
#248
wondering....
i´m using my manual brake pedals and i have done nothing to brake switch wiring what so ever
will that in any way effect the pcm
like the TCC solenoid
i got a p0740 code
if i have ignition switch on and manual press the TCC solenoid i dont get ´the click but maby there needs to be pressure on it i´m not sure about it...
can be bad solenoid too i know.....
Baezi
i got a p0740 code
Baezi
#250
Without the plate diff fluid would leak out between the trans and diff
