Pushing Water - Doing Work Myself!
#101
Here was the Damage to the Pistons:
Thanks,Matt
Thanks,Matt
#103
Now I am not Meth dependent with my twin fuel pumps, Meth will be introduced for safety and cooling!
Thanks,Matt
#104
1 Post
"IF" I remember right you have a 408 in yours which will put your Boost lower on your D1SC!
I am going to be running a 3.6" pulley on my 347 and 10.25:1 compression - I should be seeing around 18 PSI of Boost
WHY? with a post by CARTEK on the flip-drive and a extremely similar set-up to mine and a 3.4" they were seeing 22 PSI of Boost when the belt snapped and no slip -
And when I was having mine Dyno'd with the 3.4" and Pushing water with two pistons missing pieces exposing the top ring, it was hitting 16.5 PSI of Boost at 5400 RPM
So kinda doing a little in-between guessing with the current set-up, I believe it will be in the 17-18 PSI of Boost range.
Thanks,Matt
Thanks,Matt
Glad to see your build about done!
#105
I got an engine light today on the way home P0327 Front Knock Sensor - When I look back and looking at the HELMS Manual it says to Torque them to 15 ft lbs and "IF" they are "OVER TIGHTENED" you will get that code as well or low voltage - I remember that I set my my TQ Wrench wrong on those and was supposed to loosen and reset it to the proper torque, but neglected to do so, so I'll pull the manifold and redo them this week - Arrrgh!
Other than the above mentioned, and now also needing a new power steering pump pulley, (dang piece of plastic crap broke today too) all is good!
On the way to work all went real smooth as I drived normal varying the speeds. On my way home from work I varied the RPM's as well and was cruising at 70 MPH with the cruise control when the Check Engine Light came on and actually shut the Vette down, due to the P0327 code - once all calmed down and I checked everything out, I got it started after a couple of tries and again it ran super tight and smooth, although the code P0327 came back again and again.
The motor feels so good but I am really taking it slow and easy and am going to put a minimum of 500 miles on it (started this morning with 99399, so at 99899 and "IF" all is still going perfect, then it will be on to do the tuning on the Dyno.
Thanks,Matt
Thanks,Matt
#106
just reread this thread, havent read it since you posted the video. goooodddd i love the sound of d1 and f series prochargers. freaking sick man. cant wait to see the final dyno numbers. We have so many similar parts, its not funny.
btw could you tell a big difference in the dewitts rad compared to the thin stocker ?
#107
Thanks,Matt
#108
good cuz i just got me one and i was one the fence about spending that kinda money on a rad. glad i did now. Why did you lay yours down ? Did you have to do that to get the condensor to fit ? i know alot of peps do it
#109
That is the way it was done before they had the 2" shorter radiator to enable you to take your intake tube over the radiator for fresh cool air and before the had the Dongle from A&A
Thanks,Matt
#110
2018 C5 of Year Winner
Amazing your accomplishment and thank you for sharing with us. You must have perma grin Matt! Just looks and sounds amazing!
The only place you fell short was, I assumed with all the detail and mapping things out for us there would definitely be a video of you rollin out)
#111
Thanks,Matt
#112
Received 1,762 Likes
