where can I find a Breather for Drivers Side Valve Cover
Iam looking to vent the engine as much as possible I already have the filter for the oil fill and a catch can, so if anyone has a place that carrys them or a part # that would be great. Thanks in advance
If your trying to vent that small hole in the rear of the driver side valve cover I would try autozone, or oriely. I think that opeinging is around 1'' or slightly bigger.
make sure you use screen or something in the tube of the filter other wise the filter element will be plugged with oil. Same thing ECS does on there oil filler air breather modd
