Don't feel much of a difference with a 150 shot.
1 Post
I think either my kit isn't hitting right or a 150 shot just isn't all cracked up to what I thought it'd be. For those who have Stock C5 Z06's... And sprayed a 150 hit, .62N, did you feel a MAJOR difference or no? Because I thought it would hit hard and to be honest, I pulled 6 degrees on the window of spray 3200-6300, I have and I feel it would be faster with just putting the timing BACK in. I'm pretty frustrated and expected more. When it hits should I feel a MAJOR jerk of it or is this all it has to offer?
Thanks,
-Hippo
Thanks,
-Hippo
I've dynoed a lot of LSX Cars with 150shot gained 130-150rwhp 130+rwtq all the time if you didnt feel that something is wrong for sure...
Bottle pressure? Major Jerk are you sure its not running extremely rich? what was A/R ratio on the nitrous?
what kit are you using wet or dry? either way it should make a big difference. I have the NX kit on 150 setting and I leave my timing factory. The factory has the timing retarded as is, so removing even more just hurts performance.
u should feel a 150 shot.
6 degrees is alot for just 150
what kit do you have and whats the jet sizes.
I would make sure everything is good pull 2-4 degrees and make sure u have good bottle pressure 1000+ and hit it again
What they said.... 2-4 degrees of timing pulled at maximum.
The smallest shot I ever ran on a ls1 was 60, and I still felt that. Make sure both solenoids are working while the car is off.
I am thinking regardless of the timing or the jetting, you should feel something (either bogging or extra power) when you are supposed to be spraying. This makes me think it is the solenoids, wiring, or switches.
What kit are you running
Make sure you have the right F jet for the 62N
it´s probably recomended 35-38 from seller althought it may be too rich like that but it should be save.
and have a right nitrouspressure, 1000-1100psi if you donæt have the right psi or to rich blend you will not get the 150 rwhp as you hoped for.
-6 degree is smart thing to start whith for the 150 shots i would even go -8 degree at first while you are fine tuning the AFR
i ran 35F jet whith a 78N jet @62psi
seller recomended 46N but it was way too rich 10AFR
could also have glogged lines or a bad solinoid
good luck
good luck
1 Post
It's a HSW wet kit. I was running a 34F for the 62N, but switched over to a 31F. Also running an FJO Progressive controller. I tested the solenoids and they work just fine and spray good. But apparently the controller is giving me issues. It turns green when I'm in the set window switch and WOT but it doesn't hit >_>. Also on BR7's. But I'm gonna probably reset it to 4 degrees pulled, since torkmonstr has a great point.
Thank you so much for the responses! I'll let you guys know if I get it worked out!
You never did state what your bottle pressure was when the system was supposedly activated...low bottle pressure makes for a poor nitrous hit. I run between 950/1000 psi when on the juice.
Once its working right he'll feel it for sure anyway. When nitrous hits it doesn't have to build up its 150hp right now!
Also check the settings on your fjo and make sure no gears are locked out.
Did you use the rising or falling TPS wire when you wired it?
1 Post
Figured it out! Used the wrong RPM wire for the controller. And I'm liking the 150 shot! It comes in hard! And sorry for not answering you before, but I was running it at 950 psi. I plan on pulling only 4 degrees instead of the 6 degrees. I'll be reading plugs on Sunday.
What do you guys think about running a 31F with the 62N jet? I think I'm gonna throw either a 33 or 32 in there. But I know the reccomended jetting is always too fat.
Thanks for the responses!
-Rick
-Rick
-Rick
-Rick
As previously stated by another...running rich on nitrous can also be detrimental to the engine. Having a good tune prior to running the 1320' is always a good idea!
1 Post
Thanks guys! Nitrous is becoming extremely simple for me now! It had me pretty scared before, but now I'm pretty comfortable. Taking the car to the track Sunday to read plugs.
Thanks again!
-Rick
Thanks again!
-Rick
Received 1,762 Likes
Glad you got it worked out. But dont get to comfortable with it are you may get a blown motor...
-Rick
-Rick
