Supercharged A&A Best Decision Ever
Some LS6 run strong. My dyno run at @ A&A was 584 rwhp and 504 ftlbs of torque. The Lingenfelter high volume fuel pump that came with the kit could not supply enough fuel so we also installed a KB Boost a Pump to keep up.
LeoLivinLife (06-11-2020)
Awesome! These cars are so much fun with a SC system on them. How much boost and what pulley size are ya runnin to get those numbers?
Have fun and past posts are correct, its a sickness!
Darion
Darion
Because of the design where boost is blowing off when not deep in the throttle and the fact that my mpg has not dropped at cruise (although injector size changed so might not register) I don't see a problem when it comes to passing the sniffer test.
If it is the visual, the headunit is carb and Andy is making the entire kit carb, actually used my car for test fit on some components. So either it passes visual, I change components to new carb stuff, or get registered in a state that has brains like Nevada! Can never understand these ca people at carb, it's all money! I remember back when I had my m5 smogged and the idiot didn't know they came with headers so would pass me!
But look, I'm pretty sure it will pass and Andy gives so much support if I had a problem I know he will help sort it out That's why I like A&A is the support.
Lastly, go put other stuff on the car other than supercharger or even carb stuff and I guarantee a ca smog tech could find something to complain about. Thus it's just not worth worrying about. I paid to have a 700 hp car and that's what I got and Im happy!
Thanks man, funny on pics cause all are just iPhone but with all the apps they make it's so easy to mess with them too like HDR.
Cheers man
ISIS SUCKS FAT CHOAD
Well, I haven't tested so I dont have a 100% response but....
I know our emissions are brutal here. I think you may be ok when the time comes for a smog check. I also read about A&A applying for CARB certification. That would be awesome.
From what I understand... in 2013 there will be no more sniffer at the tail pipes. It will just be visual and OBD2 plug in.
Yes California is a beautiful state with great year round weather but the laws and regulations in general are making the beauty and great weather much less attractive these days.
#34
Yeah I haven't lived in Michigan since I was 20 years old. I'm 29 now. Never had to worry about it in Michigan I'll be damned if I'm going to start now. everything has a price including emissions testing.
Also I can drive my corvette here year round when it's running. . Couldn't do that in Michigan.
#35
I have friends in Michigan and have been there twice in the summer.
I spent all my time in the SE parts of Michigan.
I actually really like Michigan but being born and raised here in southern California, might be hard for me to assimilate to the cold weather. Being 49 might make the adjustment even tougher.
I guess there is a trade off one way or the other...
#36
Always is wherever you are. On one hand, lots of stuff is more expensive over here and the winters suck.
On the other hand, last week I hit 175mph legally on the Autobahn in convoy with a BMW M Coupe
BTW- at that speed the car was still pulling in 6th gear. I didn't expect that...
#37
Car has the base kit from A&A which comes with a 3.8 pulley and boost on the gauge reads about 9 or 10psi when full on at readline.
All I know is that it runs great! Like I said, no overheat, no high coolant temp, no oil temps that are crazy. I decided to go with the oil fed supercharger (non self contained) for a few reasons as well. Like the fact that the oil is cooling through my system rather then stuck in the supercharger. Thought that would help some because I was unsure how hot the oil would get now that it passes and cools the supercharger. Well, it works flawlessly.
#38
Glad to hear your positive input about going FI as mine is going to ECS in a few weeks for the install and I keep asking myself is this going to be worth the big $$$'s I'm spending on this car
I pre installed my alchy kit and the ARH's should be delivered tomorrow as both will be done before I drop it off.
Hoping to get about the same HP numbers you got, don't think(hoping) I will need more.
Will be installing a clutch next winter to handle the new found power
#40
Not to mention that you cannot run longtube headers or radical cams.
Plus you cant legally run turbo(s) other than the STS kits.
