Rear mount oil tank to feed turbos
Has any one used them and which would u recommend?
I don't think it would gain you anything unless it was a "Accusump' type pressurized tank to overcome a temperary loss of PSI. Otherwise the tank pressure would be the same as line pressure.The biggest problem is getting the oil back up front.
