Rebuilding the Ghost, aka Great White
Old 12-02-2015, 02:28 PM
  #521
ajrothm
CF Senior Member
ajrothm's Avatar
Liked 672 Times in 517 Posts
Originally Posted by Turbo-Geist View Post
Agree, it's very enjoyable and the engine seems to be solid. Now I'm going to explore the limits of the drivetrain on slicks this weekend if the weather holds.
This wasn't the original plan but I've managed to make it work. With a 6 psi spring in the gates and the controller off, it is very predictable with a ramp to 20 psi. It's almost like being on a progressive with two kits, one small and one large. However, it's a handful on the street with the controller on and 20 psi very early.
Thanks, you were right. It still needs a few tweaks but everything is working out. I think I may still need a different tire for the street to maximize the potential.
You running the Quick 30 on Sunday? I may come out and cheerlead for you.
ajrothm is offline
Old 12-02-2015, 05:29 PM
  #522
setxws6
CF Senior Member
setxws6's Avatar
Liked 0 Times in 0 Posts
Glad to hear the tuning is coming together. Lmk when and where if you track it one of these weekends
setxws6 is offline
Old 12-06-2015, 08:24 AM
  #523
Turbo-Geist
CF Senior Member
Turbo-Geist's Avatar
Liked 118 Times in 106 Posts
2017 C5 of Year Finalist
I went to the track last night for some additional tuning and a little practice.
Here was the best pass with it spinning the tires at 140 mph on 18" drag radials and the controller turned off.
Turbo-Geist is offline
Old 12-06-2015, 09:40 AM
  #524
inspector12
CF Senior Member
inspector12's Avatar
Liked 73 Times in 68 Posts
Good deal. MPH shows the potential it will take some practice to get your desired ET etc...
inspector12 is offline
Old 12-06-2015, 10:04 AM
  #525
StealthFRC
CF Senior Member
Liked 43 Times in 36 Posts
What were u hitting for boost?
StealthFRC is offline
Old 12-06-2015, 10:19 AM
  #526
Turbo-Geist
CF Senior Member
Tires started spinning @ 140 mph and we're turning 158mph when I crossed the line. Boost is 9 psi @ the start of each gear and creeps to 20 psi by redline.
Old 12-06-2015, 12:52 PM
  #527
Chris Stewart
CF Senior Member
Chris Stewart's Avatar
Liked 51 Times in 44 Posts
cheering from the west coast!
Chris Stewart is offline
Old 12-06-2015, 06:40 PM
  #528
ajrothm
CF Senior Member
ajrothm's Avatar
This wasn't his quickest pass but it was a clean one. I'll let him post his new PB..
ajrothm is offline
The following users liked this post: ajrothm
a/c man (12-09-2015)
Old 12-06-2015, 09:06 PM
  #529
Turbo-Geist
CF Senior Member
Good job on the video, Alan. Great seeing everyone at the track. Here's my new personal best. [email protected]
Old 12-06-2015, 09:19 PM
  #530
cmiller8006
CF Senior Member
Liked 12 Times in 12 Posts
That's some nice mph
cmiller8006 is offline
Old 12-06-2015, 09:26 PM
  #531
winters97gt
CF Senior Member
winters97gt's Avatar
Liked 60 Times in 50 Posts
winters97gt is offline
Old 12-06-2015, 10:49 PM
  #532
Turbo-Geist
CF Senior Member
Good angle, Mark. I think this is where I'll find some ET. Left side of split screen is from the old combo. At 100% tps it was at full target boost. The new combo takes 1.25 seconds to hit full boost after 100%. I have a light spring in the gates and they aren't responding quick enough with the controller.
Old 12-07-2015, 02:47 AM
  #533
inspector12
CF Senior Member
Congrats Ben on a NPB and a great shakedown day at the track! I'm happy for you bro!
Old 12-07-2015, 05:03 AM
  #534
ajrothm
CF Senior Member
ajrothm's Avatar
34 mph back half.....
ajrothm is offline
Old 12-07-2015, 08:16 AM
  #535
jimbos'ss
CF Senior Member
jimbos'ss's Avatar
Liked 34 Times in 34 Posts
That thing is moving! One hell of trap speed.
jimbos'ss is offline
Old 12-07-2015, 09:33 AM
  #536
Turbo-Geist
CF Senior Member
Thanks, Jeff. Glad I landed in the targeted range that we discussed for a 1st trip. I think once I get it to make full boost on each shift, the ET will drop more.
It rolls on the big end. Glad you made it out there. Looking forward to seeing your car running again.
Thanks, it felt great. Hoping to go even faster next outing.
Old 12-07-2015, 09:42 AM
  #537
slow ride
CF Senior Member
slow ride's Avatar
Liked 10 Times in 10 Posts
You are killing it for having so little wheel time in a few years. What rear wheel/tires again? I thought they were a full hoosier slick in 28" x 10" x 17" on a zr1 17" x 10", but not sure. I'm debating on a qtp in 11.5" or the 10" slick. I noticed you are using the MGW shifter now so curious if you like it over stock?
slow ride is offline
Old 12-07-2015, 09:51 AM
  #538
Turbo-Geist
CF Senior Member
Notes from this trip:
-Changing four tires in the parking lot with hand tools and a jack is not very enjoyable. Glad the weather was nice and cool.
-After that was done, I found a vacuum/boost leak. It was the geeky small black plastic line at the back of the intake manifold for the a/c. That thing is entirely too short and hard to reach. I had to borrow tools and pull the coil packs and valve cover. I ended up sticking a golf tee in the rubber 90 at the back of the intake to plug the leak. This will be fixed before the next trip so that it is never an issue again. (One hour wasted)
-Next it was time to do more tuning. It's been almost impossible to tune the car on the street with the power it makes so I made multiple 3rd gear pulls on the track with the slicks on the car. (More time)
-Finally it was time to make a pass with the controller off. I think it went 10.41 @ 141 because the ramp is so slow with the 6# spring in the WG.
-I started playing around with the controller. On the 9.99 @ 148 pass, the driver side window popped out and dropped down into the door. We spent almost another hour in the pits, pulling the door panel, fishing the window out and getting everything re-aligned. Thanks to Jon, Joe, Bill, Jeff, Alan, and anyone I forgot for their help on this one.
-Back to the starting line. This would have been a beautiful pass, but it went into REP mode in the middle of the launch. The computer freaked out because the airflow was greater than it thought it should be for the throttle angle or maybe the blade was open more than commanded.(1515 code). I told it to ignore the code and went back for one more.
-Last pass was [email protected] I probably could have made one or two more but I was beat. I hadn't eaten since 8am and it was now 3:30pm. I still had to drive the car home and needed to bolt the drag radials back on for the ride.
-Looking forward to the next one and hope there is less drama, more driving, and quicker ETs
Old 12-07-2015, 09:57 AM
  #539
Turbo-Geist
CF Senior Member
Thanks, man. I was a little rusty after being away for 2 years. The shifting got better each pass. I just need more practice. The rear wheels are a 17X10" Fikse Profil FM5 and Hoosier slick 17 x 10.5 x 28.
I'm really happy with the MGW shifter and the 6060 trans. I didn't have to think much about shifting. Just need to practice and get quicker. My shifts for this trip were in the 0.2s range. I used to be 0.15 to 0.1s range. Looking to get to 0.1s or quicker after I get everything lined out.
It's tough being the mechanic, tuner, driver, and pit crew all at the same time. This is how it goes with a new combo. It should be even better next time.
Old 12-07-2015, 11:01 AM
  #540
schpenxel
CF Senior Member
schpenxel's Avatar
Liked 763 Times in 709 Posts
St. Jude Donor '15
You need a cordless impact
I like the 2763 from Milwaukee.
schpenxel is offline
Quick Reply: Rebuilding the Ghost, aka Great White
Sponsored Ads
Vendor Directory
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
