Twin Turbo C5Z
Old 02-05-2018, 02:41 PM
  #121
jimbos'ss
jimbos'ss's Avatar
Originally Posted by SBCGENII
Nice work. You can do my car next.
Sure but you gotta move back to killeen.
Originally Posted by The Race Engine Shop
She's Lookin Race Ready!
getting close!
MVP @ TheRaceEngineShop (02-05-2018)
Old 02-19-2018, 08:54 AM
  #122
jimbos'ss
jimbos'ss's Avatar
Getting closer. The intakes are all tac'd up. Working on the charge piping now. Hopefully I can get everything off to coating by next week.
Old 02-19-2018, 11:06 PM
  #123
0MVP @ TheRaceEngineShop
Former Vendor
MVP @ TheRaceEngineShop's Avatar
Your fab work is lookin good Jim!
Old 02-19-2018, 11:09 PM
  #124
Former Vendor
IN case y’all don’t know what’s really impressive is that Jim drives this car daily so he Fabs stuff then puts her right back together so he can keep driving.
to you sir!
Old 02-20-2018, 07:14 AM
  #125
Turpid porpoise
Turpid porpoise's Avatar
to you sir!
That is definitely the most impressive part. I could never even consider doing that lol
Old 02-20-2018, 10:57 AM
  #126
slow ride
slow ride's Avatar
Jim, what block is that a gen 3 l33? I see it has the knock sensor location in the valley so I was curious if the bores are siamese or not. Looks like you used the texas speed 3.820" boost pistons with k1 rods and 3.622 k1 crank? That should be a stout piece, did you pin the mains or anything?
Old 02-22-2018, 10:35 PM
  #127
Former Vendor
it is a gen III Block. Spot on with the pistons and rotating assembly. (nice pistons if I may say so myself I really like the design)
no pinned mains. Just arp studs.
slow ride (02-23-2018)
Old 02-24-2018, 11:32 PM
  #128
jimbos'ss
jimbos'ss's Avatar
It's a huge pain in the butt and is actually slowing everything down.
It's an LM4 block basically the same as an L33 block.
Thanks Mike!
Old 02-25-2018, 06:24 AM
  #129
Turpid porpoise
I believe it! I’ve been putting off taking my setup apart to clean everything one last time before the first start but I keep putting it off.
Old 03-06-2018, 08:31 PM
  #130
jimbos'ss
jimbos'ss's Avatar
Yeah I have too much stuff competing for my time. I was planning on going to tx2k next weekend but I haven't even finished the down pipes...
Old 05-20-2018, 06:15 PM
  #131
jimbos'ss
jimbos'ss's Avatar
Been a while since I had time to work on the car. All my spare time has been spent with my new CNC plasma table.
I did finally manage to fab up the downpipes. Still need to weld them up. Ran out of Argon on the final tack weld. I did take the time to 3d print some pipe fab tools similar to the ice engine works kits. That actually helped a bunch.
Old 05-27-2018, 09:52 PM
  #132
jimbos'ss
jimbos'ss's Avatar
Progress is slow but the DP's are all welded. They need a bit of tweaking which hopefully I'll get to tomorrow.
Old 05-28-2018, 12:23 PM
  #133
jimbos'ss
jimbos'ss's Avatar
I designed and cnc plasma cut some new wg flanges.
Old 05-29-2018, 11:27 AM
  #134
JoeyG
JoeyG's Avatar
Cruise-In III Veteran
Cruise-In IV Veteran
Very nice build thread and fab work
Old 05-29-2018, 07:40 PM
  #135
jimbos'ss
jimbos'ss's Avatar
Thanks Joey!
Old 07-06-2018, 09:33 AM
  #136
jimbos'ss
jimbos'ss's Avatar
Some slow progress.
Old 08-08-2018, 02:40 PM
  #137
jimbos'ss
jimbos'ss's Avatar
New ac compressor setup allowing for more intake room. On to the final welds and assembly 😁
To Twin Turbo C5Z
Old 08-08-2018, 07:30 PM
  #138
jimbos'ss
jimbos'ss's Avatar
All charge piping welded up and bolted in. Off to the intakes next.
Old 08-09-2018, 05:04 PM
  #139
TastyBacon
TastyBacon's Avatar
Geez, the rest of us were just catching up with our CTS-V setups, and you go and do this! Compressor looks like a Sanden, but I don't recognize the bracket. Very cool.
Old 08-09-2018, 05:53 PM
  #140
jimbos'ss
jimbos'ss's Avatar
brackets are designed by someone on here. He's monitoring this thread. It is a sanden, and a small one too. It gave me an additional 3 to 4 inches clearance over the ctsv compressor. Gives a ton of extra space for the intake tube and coupler. I still need to figure out belt length on it and redo the ac lines. I'll post up once I do. Right now I'm ***** deep in finishing up the rest of the car so I can do a first fire this weekend.
Quick Reply: Twin Turbo C5Z
