Twin Turbo C5Z
Old 08-09-2018, 07:07 PM
  #141
jimbos'ss
jimbos'ss's Avatar
Getting so close to the first fire.
Old 08-09-2018, 10:33 PM
  #142
jimbos'ss
jimbos'ss's Avatar
Oil drains welded and installed.
Old 08-11-2018, 10:26 AM
  #143
stevieturbo
stevieturbo's Avatar
For compact oil drains...these work good, just chop off the threads and weld on a bit of 5/8" alloy tube
https://huronspeed.com/product/huron...nge-side-exit/
Or I'd have slotted the difficult end so you wouldnt need to fully undo that bolt.
Old 08-11-2018, 10:41 AM
  #144
jimbos'ss
jimbos'ss's Avatar
I have fairly easy access to both inside bolts with a wrench. One of the big goals for this setup was to make maintenance easier than the last setup. So far it's much easier to work on.
Old 08-11-2018, 10:59 AM
  #145
stevieturbo
It's definitely an important consideration when building anything.
Old 08-11-2018, 07:19 PM
  #146
jimbos'ss
jimbos'ss's Avatar
Absolutely!
Todays progress so far:
Welded up the intakes and test fit. Then added one way check valves for the vacuum source on the pcv system.
Old 08-11-2018, 09:37 PM
  #147
jimbos'ss
jimbos'ss's Avatar
Final pics for today.
Old 08-14-2018, 02:41 PM
  #148
TastyBacon
TastyBacon's Avatar
Wow, I'd never seen those, pretty cool. I made this for my car since I don't have a TIG. Fits a 3/4" drain hose. Didn't think of slotting the end though, that's a good idea.
Jimbo, car is coming along great. Your fabrication looks really nice.
Old 08-14-2018, 11:45 PM
  #149
jimbos'ss
jimbos'ss's Avatar
Thanks! Still learning, hopefully someday I'll be good enough to do it for a living.
Old 08-15-2018, 11:53 PM
  #150
jimbos'ss
jimbos'ss's Avatar
High temp paint baked on.
Old 08-16-2018, 10:41 AM
  #151
BLOWNBLUEZ06@RKT Performance
Supporting Vendor
BLOWNBLUEZ06@RKT Performance's Avatar
Originally Posted by jimbos'ss
Built a set of motor mounts to add more clearance for piping.
Gave me a ton of room!
Test fitment and clocking the turbos.
Haven't visited this thread in too long. Really nice work! I love your custom engine mounts! I was looking at mine and how much material I needed to remove to gain good clearance and came up with the same idea of just rebuilding them. I hope your transmission is doing well.
Old 08-16-2018, 08:54 PM
  #152
jimbos'ss
jimbos'ss's Avatar
Thanks Bret.
I'm gonna start making these on the plasma table soon. They'll be cheaper than hinson mounts too. Transmission is fine, diff is a little noisy. Gonna try some amsoil goodness in it and see if that helps.
Got a ton of cleanup to do but. It's almost wrapped up.
Old 08-23-2018, 10:08 AM
  #153
jimbos'ss
jimbos'ss's Avatar
Painted the intakes. Also picked up some new k&n filters. Right now my Son is in town visiting or I'd already be tying this build up.
Old 09-01-2018, 08:09 PM
  #154
jimbos'ss
jimbos'ss's Avatar
Decided to shorted the intakes for better access. Added a new radiator too.
Old 09-02-2018, 06:18 PM
  #155
jimbos'ss
jimbos'ss's Avatar
Up and running. Wasn't prepared for how loud the external wastegates would be...
Time to get it cleaned up now.
Old 09-03-2018, 04:55 AM
  #156
stevieturbo
What I found with mine, where they vent under the car is that I find them horrendously loud....but from outside the car, comments from others etc etc....they're really not loud at all.
Old 09-03-2018, 05:11 PM
  #157
jimbos'ss
jimbos'ss's Avatar
Idk if I can live with them dumped. I like my car quiet. I will probably route them back into the downpipes.
To Twin Turbo C5Z
Old 09-03-2018, 05:51 PM
  #158
sabastian458
sabastian458's Avatar
thats my plan with my setup. I don’t like the open dump sound
Old 09-03-2018, 06:08 PM
  #159
stevieturbo
I fully agree, but as mine isnt a daily I decided I'd live with it.
That said, I did DIY fab some small mufflers to try and dampen the noise a little from some aluminium tube for an outer shell and some 2" perforated tube for the inner.. Not really sure how much it quietened them though lol, they were only about 5" long.
Old 09-04-2018, 03:46 PM
  #160
slow ride
slow ride's Avatar
Question, why did you not put the filters over the radiator like the early pipes were built for?
Quick Reply: Twin Turbo C5Z
