Twin Turbo C5Z
Old 09-04-2018, 09:16 PM
  #161
jimbos'ss
jimbos'ss's Avatar
Originally Posted by sabastian458
thats my plan with my setup. I don’t like the open dump sound
yeah, it's pretty unnerving the first time you hear it. I thought I blew out a vband or something.
Originally Posted by stevieturbo
I fully agree, but as mine isnt a daily I decided I'd live with it.
That said, I did DIY fab some small mufflers to try and dampen the noise a little from some aluminium tube for an outer shell and some 2" perforated tube for the inner.. Not really sure how much it quietened them though lol, they were only about 5" long.
Not enough room for a muffler in my setup. Routing them into the DP is easy though.
Originally Posted by slow ride
Question, why did you not put the filters over the radiator like the early pipes were built for?
Ease of access mostly. I never really wanted them to go over the radiator. When I do the new shroud it'll make more sense. Trying to fit the intakes and the charge pipe through a shroud that seals on the sides would've been a huge PITA. My original goal was to keep both the charge piping and the intakes between the frame rails and run them over the stearing rack and into the front bumper. The abs module and power stearing pump made it too difficult to get all the piping through though.
Old 09-05-2018, 06:46 AM
  #162
stevieturbo
stevieturbo's Avatar
Long term, and for a quiet daily, routing them back into the exhaust makes the most sense.
When I built my turbo setup...for most part I was too lazy to do it as vent to atmos was just easier. I've learnt to live with it as is though.
Old 09-06-2018, 12:28 PM
  #163
FourG63 97GST
FourG63 97GST's Avatar
What I found with mine, where they vent under the car is that I find them horrendously loud....but from outside the car, comments from others etc etc....they're really not loud at all.
the noise deflect off the ground, and resonate back into the cabin, turns your car into a speaker basically. divert them away from the car. from the driver seat, dumps will always be louder than a hood/fender exit exhaust setup.
Old 09-09-2018, 09:15 PM
  #164
jimbos'ss
jimbos'ss's Avatar
New shroud built out of HDPE. Stuff was a pain to cut and really resistant to heat forming. I ended up using a torch.
BLOWNZO6 (09-10-2018)
Old 09-10-2018, 12:22 PM
  #165
TastyBacon
TastyBacon's Avatar
Nice use of CAD (Cardboard Aided Design)
Old 09-10-2018, 02:02 PM
  #166
Turpid porpoise
Turpid porpoise's Avatar
Loving the shroud. I've made some progress on my new radiator cradle so I'll be sending you some pics here shortly.
Old 09-10-2018, 05:46 PM
  #167
jimbos'ss
jimbos'ss's Avatar
I love that! I'm actually gonna make a .dxf for this in CAD though so next time it can be routered.
Thanks! Looking forward to the pics.
Old 09-25-2018, 10:02 PM
  #168
jimbos'ss
jimbos'ss's Avatar
More pics coming this weekend.
Old 09-27-2018, 09:25 AM
  #169
Turbo-Geist
Turbo-Geist's Avatar
2017 C5 of Year Finalist
There has been some great fabwork and innovation on this build.
Is boost control acceptable with the gate on the turbine housings?
Remind me, did you go T3 or T4 flange?
I noticed the roll bar. What brand is it and do you have some track outings planned?
Old 09-27-2018, 02:20 PM
  #170
jimbos'ss
jimbos'ss's Avatar
Thanks Ben!
Boost control has been perfect. I've only run it off the 5lb springs so far and it hits 5lbs and holds. We'll see what happens when I turn it up. I'm gonna put in 10lb springs prior to that.
T3 flanges.
It's a wolfe racecraft 6pt bolt in. I'm planning a track visit the very first weekend after I get a couple things lined out.
Old 10-07-2018, 07:51 PM
  #171
jimbos'ss
jimbos'ss's Avatar
Well I started tearing it down to put the new lifters in and fix a couple exhaust leaks. When I pulled the manifolds I found the ceramic coating chipping off, so I sent them back to be recoated. I added some flex pipes to the downpipes so there wouldn't be any stress when bolted up. I also picked up some cheap ebay pieces and build a vacuum manifold. Car should be back together and running tomorrow.
Old 10-08-2018, 12:35 PM
  #172
jimbos'ss
jimbos'ss's Avatar
Got everything back together. So far no more exhaust leaks. Going to get engine coolant. Once it's nice and hot I'll retorque everything.
Old 10-28-2018, 02:35 PM
  #173
jimbos'ss
jimbos'ss's Avatar
Rollbar install: interior out, bars in.
Lined up, bolted up.
Shampooed and cleaned all interior pieces.
Trimmed the bolts and installed the interior.
Not she's legal.
Old 10-28-2018, 02:48 PM
  #174
jimbos'ss
jimbos'ss's Avatar
Dealing with under hood temp issues. Mostly fuel boiling in the lines and rails causing lots of transient throttle issues.
First step insulate the fuel lines with insulation sleeves and reflective aluminum tape.
Next step, vent the hood.
Just need to glue them down now. Trying to figure out what makes the best bond between abs and fiberglass.
Old 10-28-2018, 03:09 PM
  #175
stevieturbo
I think it's safe to say, even if the rails were dead ended, the chances of the fuel boiling in there causing problems is almost zero. Especially given the pressure inside the rails.
Old 10-28-2018, 03:26 PM
  #176
jimbos'ss
jimbos'ss's Avatar
The fuel lines and rail were so hot you couldn't touch them. When I would prime the pump after running, you could hear the return fuel reacting to the cooler intank fuel. The car also kept pulling fuel in the tip in region and the longer it ran the more positive the trims would go. If it wasn't boiling in the rail, it was definitely evaporating coming out of the injector.
Old 10-28-2018, 08:21 PM
  #177
neutron82
Support Corvetteforum!
neutron82's Avatar
Received 1,260 Likes on 1,055 Posts
what kind of vents are those?... they look better than the track spec and good job on the install
To Twin Turbo C5Z
Old 10-28-2018, 09:01 PM
  #178
jimbos'ss
jimbos'ss's Avatar
2014 Ford mustang vents
Old 10-28-2018, 09:04 PM
  #179
neutron82
neutron82's Avatar
thought so lol... I had been looking at the carbon apr vents, they make them for mustangs and the others are universal... do you happen to have the length and width of those?... apr doesn't list the measurements of the mustang vents since they are direct replacements
Old 10-28-2018, 09:17 PM
  #180
jimbos'ss
jimbos'ss's Avatar
I'll measure them for you.
Quick Reply: Twin Turbo C5Z
