LG Motorsports C5 1 7/8 Super Pro's
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
All of you are familiar with our extremely powerful and popular 1 3/4 Super Pro Long Tube headers, but for those that have done a 427 swap or pushing a lot of boost, did you know we also have a 1 7/8" primary design as well?
For those that need the bigger pipes, our 1 7/8 system was designed to give you the most power we can across the board. These are slightly shorter than our smaller 1 3/4 headers to help squeeze the most power from your combo!
Like all Super Pro headers, these feature thick header flanges with huge 1 7/8" primary openings flowing into our famous merge collector with built in fire cone for the ultimate in HP gains! All headers come with factory AIR injection fittings, and dipstick hold down bungs. Front 02 sensor bungs are included at the collector as well.
The mid section uses a high flow Siamese design X pipe that continues at 3" all the way back to the muffler flanges like all LG header kits. Rear 02 sensor bungs are included into the X pipe. No welding, no cutting, completely bolt on start to finish!
All kits will include multilayer metal header gaskets, all required 02 sensor adapters/extension, clamps an any needed hardware.
MSRP $1695.95 w/o cats and $1995.95 w/high flow cats
All kits will be supplied with off-road pipes, even cat systems.
Fits 1997-2004 C5 and C5 Z06
Flange Close up with high quality tig welds
Merge Collector with built in fire cone
Choose the best, Choose LG Motorsports!
