Junkyard 5.3 build
#81
New updates to this thread. This is no longer gonna be a junkyard engine. MVP is throwing together this 5.3 with a set of wiseco pistons, k1 crank and rods. Parts pics coming next week.
blackmachdown (09-18-2017)
#84
The gen4 rods look pretty strong to me and I'm thinking a stock rod, crank bottom end with wiseco forged pistons should be pretty stout
the 4.8/5.3 motors are "throw away" as no one wants the small bore stuff but there is no doubt that the blocks are stronger than the ls1/ls6 blocks
talk to a machinist about working on the iron blocks vs the alum ls1/6 blocks and you'll see why the iron blocks are so much stronger
I think the alum l33 and variants provide the best of both worlds, strong block, and light weight.
Love to see the "lil thumper" builds as these engines seem to live well on low coin and check all 3 boxes good fast cheap
hard to do
hard to do
#86
hard to do
hard to do
#87
hard to do
hard to do
The L33 only came in select 05-06 silverados, but there's actually 4 versions of the aluminum 5.3. LM4, L33, LH6 and LH8. The LM4 and LH6 are fairly common as they came in all the v8 equipped gmt3600 vehicles except the TBSS and 9-7x Aero which are LS2's. The LM4 and LH6 both have dished pistons. The LH6 is gen 4 though.
