oil bypass adapter question
the oil bypass adapter that came with my STS kit to feet my turbos with oil only has one line on it where I have seen others with two lines, would I be able to purchase one with two lines and use the other side as an oil return? it would then be taking oil from the rear side, sending it to the turbos, then coming back to the turbo oil pump and back into the front of the adapter...
Let us know what you find.
