Injectors for 750whp on E85
What do you want to spend? You would need 80-100 lbs or so. I have FIClinic 1100's which at our 58-60psi base (4 bar) are pretty much like the other 127lb injectors. Mine work perfect and at that power would only be ~70% DC without checking my logs.
Really? What AFR are you targeting? Pure E85 or is it a lower concentration like e70, etc. I guess knowing the dyno you are on helps also if it's a stingy one.
haven't gathered enough data yet, stopped dyno tuning at 91% IDC @6000rpm , at 10.9afr, on the street, saw 115% @7200RPM, yea I can lean it out to 11.7ish, but still won't be in a comfy range and still looking for more power. this is on pure E85, so Just trying to get an idea where everyone else is.
If your fuel pump can flow enough at higher pressures raise base pressure to 70ish. It'll make a difference. Unless you just wanna buy bigger injectors. Idk my power level exactly but I'm trapping 125+in the 1/8 and my injectors are 105lb at 65 base psi and running e85. I'm running the Deatschwerks 90lb LS3 injectors and I'm at 95% duty cycle!
Have you watched fuel psi during a pull?
