**C5 High Horse Power Club**
#43
Location: Stealth So Cal GOCC ...comming to invade your neighborhood soon
I guess I must have fallen off the previous list.
LS6 346, 91 octane, ATI D1sc, 8 rib, 12PSI, Alky control Meth supplement, 6k rpm, forged internals, my fuel system, my intercooler/intake system, built in 2004 and 60k roadcoarse miles on this motor. 744hp/651tq
#49
Below is a video from getting retuned after rebuilding the motor. Still stock bottom with upgraded bearings and rings, only new mod was getting the heads ported with 3 angle valve job and a ever so slightly bigger cam. Run was done on a dynojet and it was a cold day I believe 40degrees. I ended up maxing out my maf right after redline hence the rising afr there. Car made 730whp/601wtq.
A & A Supercharger 3.6 pulley
Methanol Injection
LS2 TB
Fast92 IM
Ported 243 Heads
CompCam 220r, 220/220
Clevite Main/Rod Bearings
Sealed Performance Piston Rings
Stock Pistons/Rods/Crank
FLP Catted Headers
GHL Exhaust
Link to video of run....
Methanol Injection
LS2 TB
Fast92 IM
Ported 243 Heads
FLP Catted Headers
GHL Exhaust
#58
Received 1,260 Likes
need mine updated when you have time please... 795/682 346ci, D1SC, 16psi, 93/Meth (Stock Bottom/Stock Heads)
#60
Went to a BMW dyno day to see what power its making on big boost. 22psi resulted in 1080/1047 with timing still very safe.
