Single Turbo C5 FRC Build Thread
Old 03-30-2016, 10:19 AM
RU_VVET
RU_VVET's Avatar
Downpipe coming along nicely. 4 inch. So far, we haven't had to modify anything aside from A/C lines and pull wires out of the way.
Old 03-30-2016, 10:40 AM
JoeyG
JoeyG's Avatar
Cruise-In III Veteran
Cruise-In IV Veteran
Looking good. Plug changes on #2 and #4 might be a pain, but none the less keep cranking on man.
Old 03-30-2016, 10:43 AM
RU_VVET
RU_VVET's Avatar
It's not that hard to take apart with all the V-bands!
Old 03-30-2016, 11:37 AM
JoeyG
JoeyG's Avatar
Very true, so very true
Old 04-02-2016, 06:36 AM
RU_VVET
RU_VVET's Avatar
More Progress
Old 04-02-2016, 12:18 PM
95wht6spd
95wht6spd's Avatar
Very nice and clean, good work.
RU_VVET (04-11-2016)
Old 04-05-2016, 07:50 AM
Tipot
Tipot's Avatar
looks really good so far. best of luck on the build . get ready to make some torque
Old 04-05-2016, 06:30 PM
RU_VVET
RU_VVET's Avatar
Split in the back to connect to my catback:
fitment past the starter
This one is a bit blurry, however, I'm not the one taking pictures. Had to move the ABS block to the fender, relocated the coils and move the meth pump over a tad.
Old 04-05-2016, 06:32 PM
RU_VVET
RU_VVET's Avatar
I saw you put down about 900hp. that's awesome!
I'll see how much this 5.3 can crank out on 15psi. I'm hoping I can at least break 700.
Old 04-05-2016, 08:11 PM
igtabg1
igtabg1's Avatar
how difficult was it to move that abs block?
Old 04-05-2016, 09:00 PM
RU_VVET
RU_VVET's Avatar
Not hard just time consuming. gotta rerun brake lines and adjust the wire harness a bit.
Old 04-06-2016, 01:52 PM
FourG63 97GST
FourG63 97GST's Avatar
jealous you found so much room to fit all that downpipe. wish I could with my hinson kit
Old 04-06-2016, 01:57 PM
  #33
RU_VVET
RU_VVET's Avatar
The trick is moving the coils to the fenders and running custom length spark plug wires. You cant do it otherwise.
Old 04-07-2016, 04:22 AM
  #34
AtlasInTheGym
AtlasInTheGym's Avatar
Holy monster of a turbo. Interested in results!
Old 04-07-2016, 10:01 AM
  #35
RU_VVET
RU_VVET's Avatar
LOL its only a 74mm. Borg Warners just look big.
Old 04-07-2016, 10:10 AM
  #36
Tipot
Tipot's Avatar
i agree . one good thing if you plan to upgrade to another brand most likely anything will fit with your kit lol
Old 04-08-2016, 12:47 PM
  #37
RU_VVET
RU_VVET's Avatar
Exhaust is done. Manifolds to axleback
Up to 4 spark plug wires now. It takes almost 20 minutes to make just one.
Oil tap and feed
To Single Turbo C5 FRC Build Thread
Old 04-09-2016, 10:26 AM
  #38
50 ANV C5
50 ANV C5's Avatar
great looking project , bummer about ecs I love my set up from them , but anyway good luck cant wait to see the final results , keep cruising
Old 04-09-2016, 10:44 AM
  #39
lsxvette
lsxvette's Avatar
looks great man
Old 04-10-2016, 07:48 PM
  #40
RU_VVET
RU_VVET's Avatar
View My Video
First startup video in 5 months. Fresh oil, lifters are ticking. It's also only running on 7 cylinders. We ran out of spark plug wire for #8. Working on that as I post this.
Blackonblacksls (04-11-2016)
Quick Reply: Single Turbo C5 FRC Build Thread
