External fuel pump ideas for YSI
Moving up to a YSI from a SI.. will need more fuel. Currently have a 255 in tank and KB BAP. Its a '99 and I already did a regulator at rail/97-98 fuel filter/-6 return line while engine was out. It is a LS3, ported, cammed, 1000cc injectors. Will be doing some HPDE stuff so pump will be cycling. It is also driven on street quite a bit.
Was planning on -10 from bottom of tank to pump and either -6 or -8 to fuel rail with a tees for stock fuel line. Do I need to use a check valve on external pump? What inline filter should I use (pre pump?)? What brand of hobbs switch are the best (seems like it would be weak link in system).
Thinking about these.. anyone have good/bad experience?
Holley 12-1600
MagnaFuel 4303 or 4301
Aero A1000
Or??
I tried the fuel calculator but could not get it to work...
Oh yeah.. pump gas.. we do not have E85 here..
Thanks!
Joe
Holley 12-1600
Aero A1000
Or??
Thanks!
Joe
Premium Supporting Vendor
Location: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Received 1,085 Likes
If you want a pre made set up ready to go, our stg 2 fuel system would fit your needs well. That has an Aero 1000 pump. PM me for details.
zrtman1 (04-12-2016)
I have a 255 in tank, and a sump feeding a Magnafuel 4703. Check valve and aero motive stainless filter. -10 up to engine that splits to twin -8 to feed the back of each rail. Magnafuel is hooked up to 5psi Hobbs switch. -10 return to top of driver side tank. Simple and effective.
12-1800 Holley here. Has check valve built in. Works flawless. 10 micron filter in engine compartment, 80-100 by fuel pump. You will need A & A bracket to mount fuel pump if C5. Call Josh at A & A. Would suggest their Hobbs switches also....set one at about 4 lbs boost...other at 6-8 for second pump top kick in.
zrtman1 (04-13-2016)
zrtman1 (04-20-2016)
Never had any issue with either.
If 1 x 044 isnt enough, use 2...if 2 isnt enough, use 3
There are some others out there claiming to offer 044 upgrades, AEM, Grams, DW.
Whether reality actually supports their claims or not is another matter...and I really doubt any of the copies will be as reliable as the Bosch.
it's easily a 30+ year old design...and still few can match it.
Just make sure any external pump like that has a good gravity fed supply of fuel.
Is the 044 enough pump? I am guessing I will be in the 800whp range?
The only thing that concerns me about the Holley pumps is I see a ton of them for sale rebuilt from Holley... anyone had problems with them?
I haven't had any issues myself. Mines been on the car for about 3000 miles I guess. The only one I personally saw have issues was because of installation error. It was mounted above the tank. It needs to be below per Holley directions.
i have an a1000 for awhile now and no complaints. if you insulate the mounting point it's a bit less noisy but I like to be able to hear it when it first kicks on so i know it's on. i think fuel pressure guage and wideband for sure would both be required at that power level though either way.
Ive run a Bosch 044 by itself to low 600rwhp in my turbo truck before running out of fuel. I now use an A1000 in it. The intank pump plus a Bosch 044, A1000, or my vettes auxillary Magnafuel 4303 would all serve you well as a boost activated second pump.
zrtman1 (04-16-2016)
So unless you have a huge motor making a ton of tq, it's probably enough pump for 1000+ on pump gas
Absolutely.
