Need help Identifying this tensioner
Hi,
I was originally told I needed 38194 gates but it was not the correct one.
I have the original first gen bracket, the one with only two pulleys. The tensioner is at the bottom. I have a picture of it if anyone can help.
Thats a stock tensioner. I have the same bracket on a customers car, you can replace it with any stock ls1 version or get the HD version of the HD trucks. There basically all the same.
Roger
Roger
a/c man (06-09-2016)
Thanks Roger. That is exactly what we did, with the HD version and swapped the pulley.
All good now.
On the old bracket it is a 38194 tensioner but you must remove the ribbed pulley and use a smooth one for anyone who had the same issue.
