Another Huron Speed Twin Turbo Build!
#221
ISIS SUCKS FAT CHOAD
Well we hit the rollers again tonight. The current clutch just can't take the power, the three year old Mantic twin gave up! This first pull was at 18psi and still pretty fat. As as soon as we leaned it up the engine blew through the clutch as soon as the turbos spooled. I firmly believe this would have made north of 1100whp once dialed in at 18psi. I am currently working with Mantic on a quad disk so bigger numbers are in the near future!
I'm sure you will get another clutch and be back at its. Very impressive for sure.
#222
#226
#227
Former Vendor
#228
#229
Also very interested in the minimum you can achieve with almost no spring, i.e. regulated by the flow of the piping.
#230
Oh, I forgot to mention that I am using the Cortex EBC.
#231
Leash controller just counts the amount of time you cycle the clutch pedal to indicate gearing, no micro switches. More for drag racing but can easily be manipulated on the street just by bumping the clutch pedal.
#232
Nice. I am curious how the leash bbg compares to eboost2 bbg. I have pretty much designed out how I was going to setup eb2 with micro switches and 4 boost groups programmed.
https://sirhclabs.com/
#233
#235
I looked at them all and played with most of them before going with the Leash, it seemed like the best designed unit of the bunch of the customer support is amazing. Not to mention its set up for C02 control out of the box.
#236
#237
#238
And most do not care where the air source comes from in terms of control
Although something dedicated to the likes of CO2 might use it with less wastage than a controller not aimed towards that.
#239
Former Vendor
#240
