Single Turbo FRC Build
#201
Small updates as I button up the last of the little stuff. Blow off valve flange is welded on, I would highly recommend Vibrant's tial bov flange to everyone welding one in. It came with a threaded, o-ring sealed stub so you can unthread the stub and flange from each other for welding. The material on the stub is also thicker than the flange that came with the valve. I welded a 10AN male onto my turbo intake and ran it to my clean side catch can, unfortunately I got ahead of myself and did it before I put the Alt back in so the line with have to be remade. I'll be using a turbo guard on the intake to provide some protection to the turbo. All thats left is to finish wiring the Fore FC3 to all three pumps, tighten down all the new AN lines, clean out the radiator pipes and buy/make an expansion tank. After that she gets fired up for the first time in over a year.
#203
So this is going to be a fairly large update lacking a bunch of photos.
I decided to switch everything over to a Haltech standalone, I gutted the rest of the interior and redesigned my fuel setup. Outside the car I've been welding pre-existing holes shut, grinding them smooth and repainting the frame, I bought a CC carbon "Stingray" hood and I deleted the ABS block. More details will come but here's what I've added since my last post.
Haltech Elite 2500
Haltech I/O Expander Box
Haltech Dual Wideband Box
Haltech Terminated LS2 Harness
Haltech Flex Fuel Sensor
Haltech Racepak IQ3
FIC127 LS2 style injectors
LS2 Style Fuel Rails
Wilwood Brake Prop Valve
3/16" Steel Brake Lines
3/16" Steel Wastegate Hard Lines
Carbon Creationz "Stingray" Hood
I might be missing a few smaller things. Pictures are in no particular order.
Haltech Elite 2500
Haltech Racepak IQ3
#205
its about time we got an update looking great man and it appears your taking your time to do it right the first time....or your just ocd like some of us and like things organized. either way, shes coming along nicely. you have any details on how you proceeded with the abs removal? also was that mainly doable because of the ecu,bcm changes
#209
The ABS delete is still in the process but you don't need to have a standalone EMS to do it. You can simply unplug the wiring harness going to the EBCM and zip tie it up out of the way.
I used:
25 ft x 3/16" steel brake line
Edelmann Brake Adapter Fittings
EDD-262400
EDD-262800
Wilwood Adjustable Brake Prop Valve
P/N 260-11179
Dorman Brake Tee Fitting 785-436 to split the rear outlet to each rear caliper
8 x 3/8-24 Inverted Flare nuts(prop valve and tee)
2 x 7/16-24 Inverted Flare nuts(MC adapter fittings)
4 x 10x1.0 Bubble flare nuts(caliper hoses)
#211
First 3 lines for the new brake setup are complete. I got both prop valve inlet lines done and the line to the drivers side caliper. This is my first time bending and flaring hard lines so it's definitely a learning process but it's not going to bad.
I ended up repurposing the mighty mouse catch can bracket I had to mount the prop valve and I'll have to, once again, move my catch can elsewhere. It just took a little cut, grind and weld and it was a perfect fit.
#212
Brake lines are done!
More importantly I took the plunge and cut into my brand new hood.
#214
My plan is to cut the pipe back an inch or two and use two more pie cuts to give it a softer turn up and out of the hood. I want to have it sit about 1-4”-1/2” above the hood line
#217
Got the tip through the hood so I guess I'm good to fire it up after I tie up a few loose ends. I have to fill the PS fluid and coolant then I think I'm good to go. I spent a few hours on the phone with Bret the other night while he set up my start up tune so I should have a video in the next couple weeks of this thing cranking for the first time.
MVP @ TheRaceEngineShop (06-15-2018)
#218
It lives!! Massive thanks to Bret(Blownbluez06) for helping me get it idling properly and chasing down a few issues. This was literally the first start up with no tuning, Bret did quite a bit of tuning on the Idle control and fueling tables to level it out.
https://photos.google.com/share/AF1Q...FmRWdDV1ktSVp3
Little teaser of something another member is working up for me.
Obligatory engine bay shots. There may be some minor changes and of course it will all be powder/ceramic coated but this is essentially it.
#220
