8 Bolt Crankshaft with C5 Flex plate?
Old 12-23-2016, 09:27 PM
C5Natie
C5Natie's Avatar
Default 8 Bolt Crankshaft with C5 Flex plate?
I just realized that the LSA crank in my new motor is an 8 bolt crank. Therefore my stock flexplate wont bolt up to it. Does anyone know if you can bolt the torque tube coupler hub to an 8 bolt LSA/LSX flex plate? Based on the pictures I've seen it almost looks like it can be done.
Old 12-23-2016, 11:20 PM
Shoaf85
Shoaf85's Avatar
RPM transmissions set me up with a custom flexplate they have made just for this application. Also from what I've "heard" a C7 flexplate will supposedly be a direct fit as well. Not sure if the C7 has an 8 bolt crank but I was told by someone that it works.
Old 12-24-2016, 01:00 AM
C5Natie
C5Natie's Avatar
Thanks for the tip. Just looked at he the c7 one and man is it almost identical plus it is 8 bolt. I may buy one and test it. Found a used one for $120
To 8 Bolt Crankshaft with C5 Flex plate?
Quick Reply: 8 Bolt Crankshaft with C5 Flex plate?
