A4 conversion / standalone
Was up guys am about to start swapping out my 6speed to auto 4l60e on my 01 coupe. I don't have a harness for the trans wanted to get your guys input on the standalone harnesses they sale out ther or wat you guys using
One harness I'm looking at is the TcI ez-tcu control unit has anyone herd of it or running it on ther auto swap
wat do you guys recommend
AMP Racing
2023 C5 of the Year Finalist - Modified
2017 C5 of Year Finalist
St. Jude Donor '09-'10-'11-'12
Learn how to spell, Gangsta...
And search here. Several members are using stand alones. Most seem to use the OEM pcm to control the trans.
Save your money and DONT buy a TCI EZ ECU!! I tried one in my turbo GTO/4L80E a few yrs back.It was crap VS the PCS control box that now handles shifting duties now.Very nice piece!Call RPM transmissions,they will hook you up!!!
Get the PCS TCM-2000 controller and their GM harness. Works great and relatively easy install...
You will have to get a base trans tune from someone tho as the PCM does not come programmed.
