Adventures in Clutchland - Detail 101
I had other things to do on Saturday so I picked back up yesterday after church. Both downpipes had to be removed to get the bell-housing off. It's been a while since I've done a clutch swap with the engine in the car and forgot what a pain it is without a lift.
Here's a picture for comparison to their Figure 7.
The fingers are supposed to be below the straight edge.
Here's a measurement they asked me to get for them last week. This is essentially from the mounting face of the crank to the pressure plate fingers. ~ 3.25"
Today
I'm on the phone with McLeod right now. I sent them my other RXT 1000 and they received it Monday, April 17, 2017. I called and asked about it last week and they didn't have it in the system. Last week they said they would go look in the shop and send me an email regarding the status. This didn't happen.
I'm on the phone today and they are telling me they will go look in the shop. They go look in the shop and tell me it's on the stand for rebuild but needs a new floater plate and those aren't in stock. They expect to receive the new floaters tomorrow April 25th. The clutch can then be rebuilt and shipped.
Regarding the 3.25" measurement, according to McLeod, it should be 3.05". I'm not sure if this is when new or at the service limit. I guess when the new one shows up, I will check.
I forgot to post this picture. The clutch is designed to operate with a throw-out bearing travel of 0.450" to 0.455". This picture shows the travel on the slave to be just under 0.500". So, the slave is extending far enough to do it's job, but the clutch disks aren't fully disengaging.
Just saw a car with a bad pilot bearing that was locking up on the input shaft of the torque tube. The guy couldn't shift to reverse because it was spinning the torque tube.
Thanks. I checked the pilot bearing and input shaft and they are both in good shape. This is similar. If the disks won't separate from the pressure plate, the driveshaft is still turning and won't allow you to place the trans in any gear when sitting still in neutral. It also made the car very difficult to shift during a race before it got to this point.
I'd say that is more than enough to disengage the clutch. The fingers don't have to move very much, and the clutch disk itself only has to move a fraction of an inch. That's more than enough throw to operate a clutch.
Yes. This video was at the beginning trying to figure out the problem. I probably didn't word things correctly. There only needs to be 0.025" between each disk, so 0.050" total. It's not a 1:1 ratio between slave travel and pressure plate movement. They specify 0.0450" to 0.455" of slave travel and I believe I have verified it has enough movement. There appears to be a mechanical issue with the clutch/pressure plate assembly. With the pedal depressed and the slave as shown in the video, the pressure plate is still in contact with both disks.
Status Update
The car is completely torn down waiting for a new clutch. I'm planning to go to the Pump Gas Invitational and race on May 13th so time is ticking. McLeod has the spare RXT clutch and is in the process of upgrading it to an RXT 1200.
I have been talking to them about the issues with the current RXT 1200 and they agreed to pay for shipping back to their facility. I'm not sure what will happen next, but it's a step in the right direction. I will take some pictures of the rest of the parts tonight and then ship the clutch assembly back tomorrow.
Your giving great info on Mcleod rxt clutches that is a hit or miss with these clutches. I'm in the same boat with this clutch. My going to go with the mantic and skip the BS with the rxt when i decide to tackle the work involved. My clutch still works it's just hard to get into gear. I've put over 20k on this clutch so it's not like i didn't get my moneys worth. Just not going to take a chance on them rebuilding it and having the same problem.
Visual Inspection
I decided to take each piece apart last night for a final look before shipping it back. Judging by some uneven wear, I'm think the pressure plate surface wasn't square and flat or the disks themselves were concave/convex.
Full assembly
Top Disk (in contact with pressure plate)
You can see that there is a lot of blueing but it was hottest out toward the edges of the disk.
Pressure Plate Surface
Floater Plate Top surface
Full assembly
#33
Other info
I took some measurements back when the clutch was new and took them again last night.
New top disk thickness: 0.310"
Worn top disk thickness: 0.280"
One pad is about 0.075" thick now
New bottom disk thickness: 0.325"
Worn bottom disk thickness: 0.295"
Floater plate is about 0.25" thick
Complete assembly weighs ~ 37lbs
#37
Supporting Vendor
I had issues with my RST. I put the tick master in thinking i wasn't getting full engagement. Ended up putting a shim behind the slave this time and backing down the master cylinders throw so i wouldn't over extend the slave.
I still have some shifting issues, but once it gets warmed up it seems to be better. I'm interested to see how this thread goes because i didn't measure anything either. Just send it and see what happens lol.
__________________
Offering products from A&A Superchargers, East Coast Superchargers, Mechman Alternators, Mantic clutches, RPS clutches, Kooks Headers, Lakewood, LG, Brian Tooley Racing, Comp Cams, FAST, ARP, UPP Turbo systems, Wiseco, Callies, K1, MAST Motorsports, Haltech and many more. PM me for details.
#38
A 1/16th of an inch difference at the slave can mean the difference between having good release, i.e., 0.0125" between each side of each disk or dragging, i.e., with 0.00625" between each side of each disk. Not enough clearance will cause poor shifting and ultimately lead to worn parts in the clutch assembly and the transmission.
#39
Supporting Vendor
#40
Thanks, Bret. I totally understand what you are saying now. The only reason to shim is to get the slave within the recommended range as far as the A and B measurements. As I understand it now, this will not improve overall travel or give you more stroke. The slave is still going to travel 0.440". By adding the shim, it moves the slave forward but it ends up getting pushed back down and takes up some of the free space below. The shim only adjusts free travel but can't make up for a clutch that wasn't built correctly from the beginning. Make sense?
