Just Checking in, runway Pic!!
#41
There are actually 3 heat exchangers in front, One is the oil cooler for the Aviad 4 stage dry sump set up, 12 qt container located just below the driver head light. We actually had to remove the head light, and put in a smaller HD light in order for the head light cover to close...
The other two exchangers are both for the Air to water after cooler, they work in succession.
Do you have any pics with the bumper off so we can see the heat exchangers?
