E65 - E85 (on pump nozzle) - how to tune for it ???
Old 05-04-2017, 02:29 PM
dizwiz24
dizwiz24's Avatar
Default E65 - E85 (on pump nozzle) - how to tune for it ???
ive thought about e85 on a mild boost p1-sc 550 rwhp car, with meth/ water inj.
currently have 60 lb/hr inj and 2 fuel pumps. not sure if inj Are bigger enough but im confident my fuel pump and lines are for e85 (i have the earlier style with return fuel line):
so now the curveball is my local gas station (sheetz - kent, ohio) has a pump nozzle that says something like e65 - e85 .....Wtf.
how do i tune for an unknown quantity of ethanol :toetap
any pointers?
my goal is more safe detonation free HP (likely achieved by adding in some more timing up top ). i hope to achieve this without setting off my knock sensors
Old 05-04-2017, 02:48 PM
regorih
regorih's Avatar
You have a wideband? Assuming you have a wide band just tune it on the gas scale so normally you want to tune for 11 5 to 11 eight air fuel.
If you have 93 octane in the car right now and put e85 You should notice that your Afr gets leaner everywhere
Old 05-04-2017, 04:06 PM
dizwiz24
dizwiz24's Avatar
ok, so tune it rich for pump gas, and it will be lean/mean for e65-e85 (like 12.5:1 - which is still safe ???)
ive heard people say you need to increase spark advance up top (above 4000 rpm) to take advantage of e85 (err e65-e85.......:angrytoetap) for more hp .....
so i still envision a different tune for pump gas vs e65-85
Old 05-04-2017, 04:12 PM
junk c5
junk c5's Avatar
I use one of these to test prior to filling up.
Old 05-04-2017, 08:30 PM
regorih
regorih's Avatar
No, none of that. Use your wide band and just tune it for the AFR you want 11:5-11:8 ARF for FI setups. Yes, e85 can take more spark advance without detonation and make more power. I dyno tune many cars and see it all the time. Every set up is different and every engine likes different spark advance
To E65 - E85 (on pump nozzle) - how to tune for it ???
Quick Reply: E65 - E85 (on pump nozzle) - how to tune for it ???
