Alky - power wire
Running Guns & Moonshine
Alky - power wire
I'm wanting to keep the wiring in the passenger footwell. Is the empty number 12 fuse location usable? Just a jumper connector would be sufficient?
Ran the tubing, pump, mounted map under driver dash, have the washer tank mostly plumbed. Just need power in the footwell and to connect the tank and test it.
Hmm, second question: I can't find my led. I've got the brown/orange wire set. And I've got normal single color leds I could use. But where can I get the red/green led like the kit came with? Would there be one on autolumination.com (my preferred lighting source - after George at RadioFlyerInnovations of course)
Wire spot a legit option?
