Overspin my vortech supercharger V3 SI
Whats up guys!!
Can I over spin my supercharger Vortech V3 si from 52000 to 60,000 without any problems ??
Also I want to ask you guys if I can reach 1000 whp on my 2008 c6 z06 using C16 fuel with LS7 block with forged internals from Texas speed description as below:
( Wiseco, Diamond Racing. All pistons offered are built to accommodate LS7, and most aftermarket cylinder heads and valve configuration. All piston sets listed are 2618 forgings and feature lowered ring lands to accommodate nitrous and boost applications) ????
Whats up guys!!
at 10 psi Im doing around 770 whp on a 3.6 inch pulley Im deciding to go 3.125 pulley to go up to 15 psi but it will over-spun my supercharger 8000 rpm more than what vortech recommends, do you think i will add power or should i sell my blower and install a v7 ysi instead and then push for 15 psi ?? at this much of boost i should do +900 whp, what do you think ??
St. Jude Donor '15-'16-'17-'18
V3 blowers aren't a fan of being over spun due the oil slinger inside the case. There are quite a few threads on here where people have done this and destroyed the slinger. If you want more power get a unit that will support your goals and make sure its oil supplied.
Also, don't focus so much on the PSI you see, but the RPM's your spinning the head unit. Remember boost is a measure of restriction. With a larger engine, good flowing heads, and a cam that works with that setup you won't see the same PSI you would on a smaller or more restrictive setup.
Not even close man.
I've only ate up one blower out of 8 in 4 mustangs and vettes, and that was just bad luck of the blower feed getting clogged. As mentioned, the self contained units are great, but in the bigger Vortech/Paxton blowers, they use different bearings in non sl units. The thinner walls are a cause of concern to adding big boost to an LS7. Ask the top engine builders and those that have cracked the walls. You can resleave the block, but most guys sale the LS7 since it's worth a bunch and upgrade to an LSX, RHS, Dart, etc.
Received 1,254 Likes
2016 C5 of Year Finalist
Not even close man.
I don't know much about nitrous, but cylinder pressures would be my concern with the thin walled LS7 block. Not saying it can't be done and won't live, just prepare for the worst and hope for the best. I would put money toward a larger head unit if you want bigger numbers. Use the KISS methodology..... Keep It Simple Stupid.
winters97gt (05-24-2017)
winters97gt (05-25-2017)
About 13 years ago I was over spinning a V1 S-trim to around 66K RPM on an LT1. No issues with Vortech reliability but I topped out at 683hp at the wheels. The midrange was strong but up top I was just over heating the air and not making anymore power.
Get a bigger head unit.
If you decide to over spin it and the slinger breaks loose, you can take the head unit apart remove the slinger and convert it to oil fed. You'll have to set it up with an engine oil feed and drain and then you can spin it higher without issues. This is something Vortech isn't going to tell you. They don't want a bunch of customers bugging them about how to do it or crying because their head units broke, but what I'm telling you came directly from an engineer up there.
1. Which pulley do you think could be safely used to overspin the v3 Si?
2. Would meth injection make the added heat negligible?
3. What do you charge for the conversion? (Feel free to PM me)
