We all know that #7 goes lean first, but
what about the other cylinders?
I just had my injectors flowed and am going to put the one with the richest offset in cylinder #7. Are there other cylinders that are known for going lean? Does the port type matter? (i.e. cathedral, rectangular, etc)?
Thanks guys!
Thanks guys!
7 & 8 have been known for it, but part of it could be engine temps the rear cylinders are the hottest as well. Why do 7 & 8 still the ones that get hurt when ppl turn the intake manifolds around for intercooled race cars? GL!
ForceFedC5 (05-24-2017)
We know this ?
We know they more commonly fail first on stock engines/pistons. But that's about it, and is not the same as a claim of running lean.
Heat is the more likely reason as proven by those who reverse the intake. OEM thermostats which run seriously hot, combined with weak pistons for boost, high compression etc just dont make good partners for boosted setups
On both of the engines failures I've witnessed, neither one of them involved damage to #7. Also, the LS1 rod bolts will handle more than 500hp.
We know this ?
from what I can tell I think it's cooling issues too. I feel better on my setup running the cooling tubes to try and help with this off the back cylinders. At standing mile and 1/2 mile I've heard of guys putting in one step colder plug in those back cylinders too but I just put my two highest flowing injectors on those too and now when I pull the plugs they look the same as the others at least.
We know this ?
Thanks everyone!
I heard Kurt Urban tested it with the intake both ways and the same cylinders still had problems. That is why he sells the 4 corner steam tubes. I also have read the C5R racing program Stopped runing the rear steam tubes because it was causing its own issues and that's why the newer engines just run the fronts. I think in order to keep air pockets out of the cylinders they blocked the rears off.
I went with the expensive Kurt Urban steam tube setup, because Kurt Urban. and his design made sense to me. I would think any of the steam tube kits are better than nothing imo though
ForceFedC5 (05-26-2017)
Yeah I used to run the truck crossover in the rear and run the line up to the radiator. But another thing is the factory runs series cooling because it heats up fast for emissions, not because its best. Nascar doesn't run it like that, they run Parallel cooling etc... But dry decking the head and block works too lol!
Supporting Vendor
I'm with Kurt. The series cooling that GM decided to do with the LS isn't acceptable. I worked with H Squared racing engines to convert to parallel cooling to help with cooling issues that cause localized boiling within. That's an issue that becomes a bigger and bigger deal with increased power. I've got lines coming out the back of the heads too for a return path. Once the engine sees a certain amount of boost, I'm activating an electric water pump that pulls from the colder side of the radiator and pushes water across the exhaust side of the chambers.
Supporting Vendor
