87K Miles add supercharger, should I do more?
1998 Auto with 87k miles. Im planning on adding an AA supercharger. Besides changing the harmonic balancer, any other things I should do? Actually wondering if I should spend some money and put in a new motor? Mine runs great, but Ive rebuilt pretty much everything else, suspension, will be upgrading brakes. Just put in a 3.42 Z06 rear end with 7000 miles, so what do you think?
If you have a good tune and don't detonate the engine (stay below around 700 hp) it will likely live a happy life. If your HP goals are more ambitious, I'd wait for the new short block
Received 1,762 Likes
Thanks for your advice!
I'd do a health check on the engine and if the compression test (leak down is even better) looks good and the engine has been taken care of I'd go for it.
Im just trying to keep her fresh as a daisy, I dont think I can do a Z06 C7, even though after I sell some property I have, i probably could, but really love this nassau blue corvette. Any suggestions on this forum to get a short block?
More info will be needed here with A/A blower & what is your rwhp wants here. This will tell us what else you need to do now.
Im just looking for 500 rwhp. I use the car mainly for a grocery getter, but my grocery store is 40 miles of a killer new twisty highway near Redding, CA
You can operate everything pretty much stock, at 500 RWHP, and be fine.
However, I'd recommend a transmission cooler, and the DeWitts Radiator, to help keep it all cool, if you have the cash. More power, means more heat. Those will also better prepare you, for when/if you wish to north of 500 RWHP...someday.
Call Andy or Josh at A&A, they'll recommend the proper parts, and any further advice you need.
SuperCharged C5 Corvettes, are such a hoot to drive. It's the 'good kind' of addiction...
Don
Im already shopping for the Dewitt Radiator, and probably will do the fans too..thanks
I have a stock short block and making over 700rwhp. Car has 89k miles on it. It has had the blower since 30k miles or so. It recently lifted a head so I am doing studs. Ill run it until it lets go and build a short block.
Ryan
Ryan
]I have a stock short block and making over 700rwhp. Car has 89k miles on it. It has had the blower since 30k miles or so. It recently lifted a head so I am doing studs. Ill run it until it lets go and build a short block.
I think Im starting to get it...when in doubt, punch it!
winters97gt (06-21-2017)
Wouldn't even worry about it unless you've had valvetrain or past motor issues. Watched many 100,000+ mile and even an LS6 car with 160,000 miles slap on a supercharger and live.
Your A4 Transmission will love you, if you get it a separate transmission cooler. Don't run it through the DeWitts combo with both AntiFreeze, and Transmission fluid. Makes BOTH hotter. We put mine behind the left headlight.
Many guys told me, A4 can take a lot of punishment, if you don't get it too hot all the time. Seems true! So.....
The fans should help move air also.
Also, after it's SuperCharged, don't 'Nail it' while cruising in OD. Shift down to 3rd, then nail it. The A4 ( I was told) doesn't like that hard shift down to 2nd, from OverDrive, when going into boost.
You'll love it. It's how America's Sports Car was meant to run! Almost like stock when you're just crusin' around. And, Nothing like stock, when you nail it...
Don
Redding
nice to see someone else is on here from Redding .....sure is HOT here
Hey There, Im in Lewison, have the Lewiston Hotel. Bring your vette up sometime!
Oh and about the tranny cooler post thanks, where do I look for one of those?
Thanks for the info!
Thanks alot, that was great info...Looks like I should be buying a tranny cooler. Ill call AA maybe they could install one when I do the supecharger?
Transmission Cooler
Or do you or anyone reading this recommend the best tranny cooler? Summit shows several and different sizes
harrykerry (06-25-2017)
Lewiston Hotel
WOW pretty cool just googled the hotel and your car is parked out front in the picture. .About 30 minutes from redding I`m going have to take a trip up there sometimes.
That would be great. I have a special going on Dinner for 2 and a room $100...Kerry.....530-778-3823
1) Oil Pump
2) LS2 timing chain
3) Transmission cooler
Since you have to pin the crank and it sounds like you are going to get a new balancer, might as well replace your almost 20 year old oil pump and timing chain while you have access to it.
2) LS2 timing chain
