Help with wiring magnafuel dual relay to pump with hobbs switch
Hello, I bought a maganfuel pump and there dual relay. I need a wiring diagram of how to wire it up.
I was thinking of setting it up like this. Pin 85 goes to ground with hobbs switch spliced into it. Pin 86 to alternator or battery. Pin 87 with 30amp fuse to alternator or battery. Pin 30 to positive side of fuel pump. Is this correct, or does it need to be changed. Thanks in advance.
Terminal 30 gets a fuse and should be connected to the battery/alternator. Terminal 86 goes to the signal source(stock fuel pump power wire, switch, whatever is telling the pumps to turn on). Terminal 85 to ground with the Hobb switch in line. Terminal 87 goes the the fuel pump positive post.
Supporting Vendor
Hello, I bought a Magnafuel pump and their dual relay. I need a wiring diagram of how to wire it up.
I was thinking of setting it up like this. Pin 85 goes to ground with Hobbs switch spliced into it. Pin 86 to alternator or battery. Pin 87 with 30amp fuse to alternator or battery. Pin 30 to positive side of fuel pump. Is this correct, or does it need to be changed. Thanks in advance.
Bret
