Backwards supercharger impeller?
Cruising
I just bought this v2 used for my c5 and it looks like it's a counter clockwise volute but the impeller looks like a clockwise. Is it possible the volute was changed by some dumb a$$ and it's actually a clockwise unit? From what I understand the thread direction on the impeller shaft dictates if it's clockwise or counter clockwise and not sure what direction threads should be for counter clockwise mine looks to be like normal thread direction.
That wheel is not in good condition.
Where is the oil feed ? The oil jet will aim towards the meshing gears, so that will tell you what direction the housing had been set up for ( unless someone has changed it )
Cruising
Oh yeah it's shot and on top of that it's a cw impeller on a ccw unit. How they messed that one up is beyond me.
The oil feed hole is there just not in that photo I'll sent a pic with the hole.
Cruising
I seen that was thinking about going that direction. Did you see any hp gain? If I get the upgraded impeller will if fit the stock volute and I have the 3.6 pulley will I need to change that also? I have th v2 si trim.
Stock volute still works. Just talk to Carl. He is very knowledgeable and can tell you the difference between Si and their impeller.
Cruising
Seat of the pants says most definitely more horsepower. But i havent had it on the dyno since the "upgrade". I am making 14 psi boost now, up about 1 psi. And im only using a 3.33" pulley (56k rpms). I could pulley down cause the ceramic bearings are good to 72k rpms.
yes they rebuild as well. It's not much more if you buy their rebuild kit. It's a small amount for Peace of mind that it's done correctly.
Dodge Bruce (08-14-2017)
Cruising
[QUOTE=TX Z06 02;1595361496]yes they rebuild as well. It's not much more if you buy their rebuild kit. It's a small amount for Peace of mind that it's done correctly.[/QUOTE
Cool I'm going to call them tomorrow. I appreciate all the info. Thanks!
