Cam for boost/ tuning question for mi
Hey guys I have a 98 vette I'll be putting headers a&a kit ls6 intake...timing chain..oil pump meth kit among other things... I want a nice cam for the power I don't mind a little lobe but I want to be able to drive it around as well.... mostly just a weekend car
Josh with a&a recommended jam cam. Or the stage one a&a cam
I will also be looking for a good tune any recommendation would be appreciated
Nice how's drivability with that power...I wasn't worried about the cam until someone told me that with our pcm a big cam may not work well... even tho you have nice heads as well I thought about picking up the zo6 heads and throwing them on for like 400 but was told the power gain wasn't worth it
drivability is not a problem at all,the only thing u have to get used to is you will have instant power when you step on it,it comes in quick and will stay thru out the RPMs.
get your self some real good sticky tires.
i believe its the same specs as aruns jam cam.
