How much timing is too much? Procharger 7psi on 91 or 93 octane.
I'm trying to figure out with a procharger @ 7psi on stock ls6 with kb bap.
How many degrees of timing should it be on for either 93 octane or 91 octane?
That isn't a ton of boost, I ran mine at 18 degrees with meth at 10lbs for a long time with no issue. Make sure your AFR is good too. Start lower on the timing and increase looking for knock.
Tuning will determine this, not the internet.
SBCGENII (08-24-2017)
but dont worry about it too much. these engines dont respond to timing changes very well. +/- 2° you wont feel any difference for sure.
