Gearheads/Gurus Forges LS1 vs LS3 block
Im not sure what my heads flow compared to what your doing, I have MTI ported 241 heads with stock intake and ported throttle body. You may need some more boost to hit 850 crank.
Also if your going to be running larger bearing clearances(.002+) run a high volume oil pump. I'll be pulling mine out this winter to pull the high pressure pump for the high volume/high pressure.
My heads should flow approximately 290 CFM at .600 lift. You mentioned wholesale block and asked for my location. What was that about?
